joshuaali
SF Bay Area
I've created a list of every compatible tire from Tire Rack (i.e. passenger tires with a minimum load index of 116, or light truck tires with a minimum load index of 113).
It's split into three sheets—one for each wheel diameter. There are some filter views (Data > Filter views) to filter by type, or you can create your own temporary filter view.
Direct link
A note on weight:
  • I'm not convinced that wheel/tire weight is that big of a factor for efficiency, especially compared to a tire's tread/compound ("rolling resistance").
For the last point, this could probably be its own thread, but despite all the conjecture across car forums, the only semi-scientific test I've seen is Tire Rack's:
TireTotal weight (lbs)Average speed (mph)Fuel economy (mpg)
Michelin Energy MXV4 Plus (Grand Touring)42.538.722.8
Pirelli P Zero Asimmetrico (Max Performance)38.539.021.5
Pirelli P Zero Asimmetrico (Max Performance)48.538.821.1
Comparing the first and second wheel/tire combination, despite a 9.4% weight saving, and 1% difference in speed, fuel economy went down by 5.7%, all because of the tire's rolling resistance.
Comparing the second and third wheel/tire combination, despite a 26% increase in weight, and 1% difference in speed, fuel economy only went down by 1.9%.
tl;dr: weight probably isn't as big of a factor as you think.
derekmw
Derek
San Diego, CA
Gotta love the selection on 21" wheels
Rob O
Bend, OR
2023 R1T, 2019 RS5 Sportback, 2018 Raptor, 2020 M4
Dad
Another data field that would be good is tire weight. Some of the Plus 1 sizes for 22-inch fitment are true all terrains and Load Range E ... but weigh as much as 20 lbs more per corner! That’s a lot of inspiring mass to add. So even though they match the 20-inch tire’s 34-inch size, they’re heavier than 33-inch XL rated options (and way heavier than the efficiency-biased OE P Zeros).
CharonPDX
Charon
Cascadia
InfoSec Geek
Yep. After owning a BMW i3 with its "completely custom to it" tire sizes is exactly why I *didn't* pick the 21" wheels for my R1T.
iansriv
Would you kindly consider placing the OEM tyre on the very top so we can compare? Forgive me if I missed it.
OhioBF
Bret
Dayton, OH
Audi Q8
Cyber Investigations
22” should include Continental TerrainContact H/Ts.
invernite
NW Chicago
2015 Honday Odyssey
Clicking refresh in the R1 Shop
Thanks for putting this together!
Sevn86
2025 BMW X5 M Sport
This is great! Another reason why I didn’t go with 21” wheels.
