Because that is not where the inefficiency is located. It is located in the drive train and most importantly rolling and air resistance. The DM drive train efficiency improvements are already in the Large Pack models, and there are no aerodynamic changes. (Disconnecting one of the motors is a good idea to improve efficiency, but even that is minor compared to air and rolling resistance.)Why are you assuming that a different battery pack chemistry can't have better efficiency?
As an example, different battery chemistries will have different internal resistance and will generate different amounts of heat with charge/discharge. If less energy is spent conditioning the battery, more will be available for traction.Because that is not where the inefficiency is located. It is located in the drive train and most importantly rolling and air resistance. The DM drive train efficiency improvements are already in the Large Pack models, and there are no aerodynamic changes. (Disconnecting one of the motors is a good idea to improve efficiency, but even that is minor compared to air and rolling resistance.)
If you can point to a data based article/report that has shown a measurable improvement in mi/kWh just due to battery efficiency improvements I might believe it. In the meantime, no way.
All that could be true but for it to translate into a measurable mi/kWh improvement on the road the battery improvements need to be dramatic. I doubt Rivian has made such a significant leap in battery efficiency, but I guess anything is possible.As an example, different battery chemistries will have different internal resistance and will generate different amounts of heat with charge/discharge. If less energy is spent conditioning the battery, more will be available for traction.
This isn't related to battery chemistry, but it is also possible that the efficiency of the components in the max pack is higher so more energy from the stated capacity can flow to the wheels.
We really need a teardown of the Max Pack to see exactly what we're dealing with.
Agreed, but that's why we're impatiently waiting for the detailed EPA test data to be released. Because, at least according to the window stickers, the max pack dual motor IS more efficient than the large pack dual motor. We just don't know how or why yet.All that could be true but for it to translate into a measurable mi/kWh improvement on the road the battery improvements need to be dramatic. I doubt Rivian has made such a significant leap in battery efficiency, but I guess anything is possible.
I think it is more likely they changed the EPA test conditions to break the 400 mile threshold. That is if the usable capacity is 142 kWh instead of 148 kWh. At 148 kWh the math works out between the Large and Max.
I am not sure the EPA test data will help us understand why, unless we can tell they tested it differently than they tested the Large Pack.Agreed, but that's why we're impatiently waiting for the detailed EPA test data to be released. Because, at least according to the window stickers, the max pack dual motor IS more efficient than the large pack dual motor. We just don't know how or why yet.
If I'm reading this correctly, this CARB document appears to show the unadjusted city cycle (UDDS) range for each max pack variant?
https://ww2.arb.ca.gov/sites/default/files/classic/msprog/nvepb/executive_orders/EO Web Files/PC-LDT-MDV/2023/0006/pc-ldt-mdv_mdpv_a-480-7__sdt--20230814.pdf
ONE battery.Because that is not where the inefficiency is located. It is located in the drive train and most importantly rolling and air resistance. The DM drive train efficiency improvements are already in the Large Pack models, and there are no aerodynamic changes. (Disconnecting one of the motors is a good idea to improve efficiency, but even that is minor compared to air and rolling resistance.)
The capacity is why it can provide longer range, not efficiency. They list it as 185+ kWh. So more than 185 kWh in a Model S will make it go very, very far.ONE battery.
Dual chemistry battery in Tesla (model S?), same footprint, effective range of 750 miles for a single charge.
No change to the aero or footprint of the vehicle.
They actually have a working product, not a video of vaporware rolling down a hill.
BMW is putting eggs in the companies basket.
https://one.ai/products/gemini
YouTube Matt Ferrell Undecided just did a good video on the potential of the product
The capacity is because of the change in chemistry though.The capacity is why it can provide longer range, not efficiency. They list it as 185+ kWh. So more than 185 kWh in a Model S will make it go very, very far.
Yes. But the key is higher capacity. The efficiency of the MS doesn't change, but it goes farther because it has more kWh.The capacity is because of the change in chemistry though.
They didn't just duct tape an extra 100 cells in the back seat and the frunk.
The battery was in the same form factor of the OEM Tesla battery
The battery system has an energy density of 416 Wh/L (compared to approximately 245 Wh/L of the original pack)
That energy density improvement was achieved by using an alternative chemistry in conjunction with LFP.
These responses are too pedantic for me to care.Yes. But the key is higher capacity. The efficiency of the MS doesn't change, but it goes farther because it has more kWh.
I hope this technology turns out to be as good as they say, because this is exactly what we need.
So if that's the case, I think Im going to eventually be ok with it. I don't like the cost certainly. And I definitely don't like the secrecy.352/128kwh= 2.75
410/2.75= 149>142kwh usable
