kizamybute'
- Joined
- Oct 17, 2021
- Threads
- 80
- Messages
- 1,180
- Reaction score
- 1,997
- Location
- Los Angeles
- Vehicles
- This one, that one and the other one.
- Thread starter
- #1
I've had my truck for 14 months and completed a couple of 660 mile trips that were completed in moderate temperature climates. Usually average 2 miles per kw on 20" all-terrains. Most of this trip will be through soring temperatures above 100 degrees.
This one today will be a 754 mile round trip on 20" all-terrains, yet one size down to 276/60/20.
My trip starts off at home in Northern Los Angeles city. Heading out to Azusa, then on to Riverside to pick up, of all things; an ICE engine. From Riverside. From there, head out to North Las Vegas to drop off that engine while picking up two more ICE engines along the way. My plan will be to stop at the RAN charger in Barstow to top off, then head for Vegas to find a charger in Vegas to top off again. Drop off one of the ICE engines and pick up two more engines. From there.
Will then head back out to Barstow to top off again at the RAN charger in Barstow on my way through to Bakersfield.
From the RAN in Barstow, I will cut across the desert to get out to North Bakersfield. There I will drop off the remaining two engines. From Bakersfield, I need to find a place to top off the charge on the truck and will head out on the final leg of the trip to get me back home .
754 miles later. Certainly farther than I'll normally go in an EV, especially in a single day, so we'll see how the experience is. Don't expect much resistance at the Barstow chargers. Fingers cross for the EA chargers and that they work.
From there, will head across the 58 Freeway /' Highway to get to Bakersfield to drop off the last two engines.
FOUR Polls for this trip: (Which accounts for three stops to drop off and pickup FOUR ICE engines at three places along the way).
POLL #1; what do you think my overall efficiency will be? I am aiming for 2.0, but will be satisfied with 1.9 on the all-terrains.
POLL #2. How much time will I spend at chargers. Probably 40 minutes at each Barstow charger, 40 minutes at the Vegas charger and my final charger in Bakersfield to top off with enough to get home.
POLL #3. How long will my 754 mile round trip take?
Leaving at 7:00 AM: Figuring an hour stop at each engine dropoff / pickup spot, four charging stops at about 40 minutes each.
Seems a little Ironic that an EV will carry no les than three ICE engine with an EV vehicle.
Probably will drive between 75MPH and 85 MPH most of the way. How long do you think to entire starting point to same starting / finishing point trip will take. Which includes going up and over the famous grapevine.
Will plan food stops each time in Barstow. The rest will just be stops to top off the charge and grab a few drinks or munchies for the road.
Will keep track of logs at each stop to answer all of the above as the day goes on.
Supposed to be well over 100 degrees most of the trip, so the AC will be running.
Trip starts at 7:00 AM today. 754 miles. Four charging stops. Two stops to load and unload engines then make it back home all at a likely speed of between 75-85 MPH>
Poll #4 - How long will the entire trip take?
Will update this when I get home.
