Trailer Brake Controller -- demonstration how it's activated [video]
Drterreur
Francois
Québec city
Tesla model3 Dual motor
Healthcare
This is how you manually use trailer brakes on the Rivian.
Some have asked about actuating the trailer brakes. It’s actually more ergonomic that a “traditional” setup. Actuation pressure ramps up a bit, and is based on the set gain.
astonius
Cars
Is he pressing in on the scroll wheel? Didn't realize they pressed in as well. A nice surprise, hopefully the left one will play/pause media.
It will, as well as control volume, depending on mode.
Ladiver
Jeff
Ca
**I have not watched the video yet**
My issue with having limited dedicated buttons is that in an emergency, there is a 100% chance that you are in the wrong mode and the programmable button will not do what you need it to. Ergonomics be damned if you can't quickly and immediately deal with the emergency.
Now, talking trailer brakes, if that programmable button was tied to the wiring connector near the hitch, and always set to trailer brake when something is connected then I might be ok with that.
CharonPDX
Charon
Cascadia
InfoSec Geek
I would imagine that in tow mode, that button *ONLY* does trailer brakes, that it is no longer configurable.
Although being a strict on/off is slightly annoying, I like having an analog trailer brake controller.
That said, "in an emergency" the trailer brake controller *SHOULD* also be coupled to your brake pedal, so if you're full-force slamming on your brakes, it should be applying full trailer brakes, too. One would assume that a built-in trailer brake controller, especially on a drive-by-wire vehicle, would implement this already.
