20" Inch LT Tire Pressure (Max 80 PSI)
Best pressure for LT tires (Max 80 PSI)?
  • ~65 - best MPKs
    Votes: 0 0.0%
  • ~70-80 - bouncy-bounce!
    Votes: 0 0.0%
  • Something else, see comment below
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
ksurfier
R1SQM, Tesla
Fake Science Lead
For those that switched to 80 PSI max LT tires, what is your preferred tire pressure for everyday driving?
Some calculations:
Tire Inflation Chart for LT275/65R20 (max capacity 3,750 lbs)
Load per Tire (lbs)Tire Pressure (PSI)
1875 (Capacity of 7500 lbs)40
2067 (Capacity of 8268 lbs)44
2480 (Capacity of 9920 lbs)53
3000 (Capacity of 12000 lbs)64
3375 (Capacity of 13500 lbs)72
3750 (Capacity of 15000 lbs)80
Explanation:
  • 1875 lbs per tire: This corresponds to 50% of the maximum load, so the tire pressure is 50% of the maximum pressure (80 PSI), which is 40 PSI.
  • 2067 lbs per tire: This is approximately 55.12% of the maximum load, so the tire pressure is approximately 55.12% of 80 PSI, which is 44 PSI.
  • 2480 lbs per tire: This is approximately 66.13% of the maximum load, so the tire pressure is approximately 66.13% of 80 PSI, which is 53 PSI.
  • 3000 lbs per tire: This is 80% of the maximum load, so the tire pressure is 80% of 80 PSI, which is 64 PSI.
  • 3375 lbs per tire: This is 90% of the maximum load, so the tire pressure is 90% of 80 PSI, which is 72 PSI.
  • 3750 lbs per tire: This is 100% of the maximum load, so the tire pressure is 100% of 80 PSI, which is 80 PSI.
ksurfier
ksurfier
R1SQM, Tesla
Fake Science Lead
Bump..
richpike
Rich
6500ft ASL
Defender L663, Jeep JL, R1S
I’m not quite there yet, but this is a great question. I plan to do ~53psi when I get my Nokians. But very open to suggestions.
Following.
-Rich
jjswan33
Joshua
Sandy, OR
I run 60psi cold. My dry weight is around 8000lbs though.
ClaytonW
Nevada
Jeep JLUR, Tesla MYP, GMC Yukon XL
Passenger type tires are fitted with a 10% overage in load capability when used on SUV's, Light Trucks, and Vans because of the difference in load handling. This load overage can be removed when changing to an LT type tire. Based on the calculations I think that the correct tire pressure should be about 51 psi.
