Dent and scratches in tailgate
RivianEC
Tre
IT Specialist
Happy Spring Solstice!
Unfortunately, I backed into a concrete overhang (I am so mad with myself) this morning and got an 24 or so inch wide, 2 inch tall dent with some deep scratches along the top of my tailgate (see hopefully attached image). Anyone have an idea how much a repair would be? I’ve had my R1T for 3.5 years and this is the first dent I’ve gotten. Was just impatient this morning. šŸ˜ž
Rivian R1T R1S Dent and scratches in tailgate IMG_5269
jackfu
Boston, MA
'25 R1S; '22 SQ5
How deep are the scratches? Can you tell if it’s through clear, color, or prime?
Dents should be approachable with PDR. If scratches not too deep, a detailer could get it probably close to 90%
jackfu
Boston, MA
'25 R1S; '22 SQ5
For reference PDR usually costs me around 150-450 depending on the size of the dent. I’d ask for reputable recommendations Aron d you and get quotes/assessments. A lot of it depends on access to behind the dent. Not sure if the top of the tailgate plastic pops off easily, but if it does that might help.
captainjp
New Jersey
Gen 2 R1T
PDR for sure. I had something right in the same spot. Got it 98% perfect. The only thing was paint for me. Make sure you get the paint pen from Rivian. Mine was $550 to repair. I’d say $500 to $700 ballpark. It’s aluminum BTW.
captainjp
New Jersey
Gen 2 R1T
Extremely easy to access. Probably best case scenario for PDR
CharonPDX
Charon
Cascadia
InfoSec Geek
Battle scars are sexy.
:p
Eeyore
Bruce
Retired Union Electrician
Yes, the trim piece on the top of the tailgate can pop off (too) easily, but it's kind of a 1 time event. Plastic bits break off when it comes off so it is almost not reusable.
Mind came off when I was unloading something from the bad and rubbed over it. Rivian replaced it under warranty. The replacement has stayed attached much more securely.
Greg Chick
Greg
Tehachapi Ca. 93561
diyplumbingadvice.com
Retired Plumbing Contractor
The top plastic cap on the tailgate does pop off, dont do it in cold weather, the tabs that clip it in will break. If they do, use double sided tape to secure it back down, or screws.
What is "PDR"?
jackfu
Boston, MA
'25 R1S; '22 SQ5
Pointless dent removal. Usually involves pushing with a tool from behind or glue pulling from the front. Knock down high spots. Good techs can take out almost anything. Some locations make it harder others easier. Crease lines generally make things harder. Different metals react differently
DD4ST
Daniel
Florida
Luckily it doesn’t look like you dented a crease from your picture. This would be a tougher PDR cas if so.
