AC not blowing cold air
Rodrigo
Sacramento
2022 Tacoma TRD pro
Software Developer
I recently received my R1T, it has been sunny here in California and the cabin gets quite hot when the vehicle is parked. My experience with my Tacoma truck which also had a black interior was amazing since I pushed the ac to lowest and it would cool the cabin in minutes. Unfortunately this is not the case with the R1T, I enabled the cool cabin feature from my phone 30 minutes before I started my drive, the car was still very hot inside. I drove it for 20 mins and even though the setting was to low-cold it was blowing to temperature air.
Has anyone faced this issue?
drhnbtx
Darren
New Braunfels, Texas
"22 R1T '07 FJ Cruiser, '13 Chevy 2500, '18 XC90
My only "hot" day experience here in Central Texas was yesterday @ 90 degrees. I used the cool down feature before leaving my office. It cooled from 122 to 95 in 5 to 10 minutes(wasn't timing it) The A/C continued to cool effectively for my ride home. Sorry to hear about your experience. I would try to re-create the experience and/or contact Service Support. Best of luck, and keep us posted.
I suspect your ac/heat weren't on. Got me the first day or so. Press the button highlighted below.
Rivian R1T R1S AC not blowing cold air 20220401_143834
Rivian R1T R1S AC not blowing cold air 20220401_143847
Rodrigo
Sacramento
2022 Tacoma TRD pro
Software Developer
@godfodder0901 thanks! I do have it activated, I had a support call and they suggested to reset the car, but still same issue. They will submit a ticket to the tech team and will get back within 24 to 48 hours.
Rivian R1T R1S AC not blowing cold air PXL_20220401_222026155
PoorPilot
FL350
I have some vehicles and stuff
Did you try turning on the floor vents and seat ventilation? Both have helped in the my southern heat…this early in April.
Rodrigo
Sacramento
2022 Tacoma TRD pro
Software Developer
Yes, it is worst since the air is distributed, besides the fact the weather feels like summer time, it's simply not providing cool air. I have a 91 bmw E30 and that thing blows ice cold, I wonder if electric cars use freon and maybe it is missing. Haven't heard from support team, hopefully I will get some news on Monday.
PoorPilot
FL350
Weird. I’m Interested to hear what they say.
Rodrigo
Sacramento
2022 Tacoma TRD pro
Software Developer
Hey everyone! For those interested this is the summary of the problem.
Cause: - Confirmed condition of HVAC not blowing cold. Performed evacuate and vacuum test of the ACsystem. Passed test. Prior to filling with refrigerant, the machine performed a high pressure test.Upon that test, I heard hissing from the pressure sensor located on top of the condenser assy.Found that it was loose. Tightened the sensor and now is air tight. Filled with 750G of 1234yf.Now, system blows cold.
Correction/Remedy: - Refrigerant Evacuate and Recharge - Climate Control General Diagnostic - Low Voltage Electrical General Diagnostic
Their service team was amazing, special thanks to Katie from the West Sacramento service center. She even took care of some issues with latches of the driver side gear tunnel door and tailgate, and the headliner coming a tad bit off from the rear right passenger door side.
Truck is back on the road and ready :)
Rodrigo
Sacramento
2022 Tacoma TRD pro
Software Developer
UPDATE!
The A/C stopped working again, took it to the service center and they found a leak. It is fixed but just wanted to share if in case someone else encounters the issue with A/C not blowing cold, especially on hot days with 70 to 100 percent charge.
KYR1SMan
Robert
Kentucky
Veterinarian
We in KY had 80 degree weather last week. First time to turn on A/C. There is no cold air.. just blowing .. pet mode will not cool down cabin either. I have done a hard reboot. Made sure the blue ❄ is illuminated and power on. NO LUCK… I submitted a ticket, but will be a couple of weeks before earliest appointment. Has anyone else had this problem, and solution?
Riv E In
2024 Rivian R1S DM
I’ve got a strange one…
90+ degrees today. Cabin was 130 inside. Vented windows and remote AC before getting in R1S.
No changes to thermostat controls. 72 degrees, auto, sync. Drivers side just blew air - not cold. Eventually it blew slightly cooler air - still not cold. However the passenger side blew appropriately cooled air. Even in the center stack, the left drivers vent was blowing barely cooled air while the right passenger vent was frosty.
Has anyone else experience this? When on the same settings why would one side blow differently than the other?
Submitted service ticket but would appreciate hearing from the group.
Glembi2
Vienna, Virginia
R1S, Genesis GV70, Civic
Patent attorney
That sounds like an HVAC diverter was stuck. I’ve had diverters get stuck in multiple vehicles, just not in the Rivian.
In the HVAC menu, try turning off all of AC, sync, auto, and fan. Then turn on auto and see if the AC readjusts.
I needed to turn off all HVAC controls and reenable them when my front row passenger was messing with the front and middle row HVAC controls at the same time two different middle row passengers were messing with the middle row controls. The truck was not happy. Turning off all options then selecting auto fixed it.
I may need to purchase an etch-a-sketch and mount it in front of the first row passenger. Or just tell them the truck is now voice activated for everyone except the driver.
Riv E In
2024 Rivian R1S DM
Finally did a hard reset and it seems to have fixed the issue for now. Hope it doesn’t happen again.
