kabarec
Hudson Valley & Catskills - New York
Creative Director
Hi, anyone in the Saugerties/Woodstock/Catskills area can pull me out of the mud - just got hit with a ton of rain… Any ideas on how to get out. I have the offroad tires and a r1t dual+.
Rivian R1T R1S Stuck in mud! Help pull me out -- ideas or assistance in Saugerties/Woodstock/Catskills NY area? IMG_3715
Rivian R1T R1S Stuck in mud! Help pull me out -- ideas or assistance in Saugerties/Woodstock/Catskills NY area? IMG_3716
No_Name5330
Park City, Utah
F-150 tremor/ GMC Yukon AT4/ R1S
Oh man that’s unfortunate. Maybe you could try making some? A quick google search for “DIY traction boards” brings up lots of videos and articles and it seems pretty simple. Maybe you could try throwing some firewood under the wheels or something like that? My thinking is that maybe it would give the tires SOMETHING to grab onto.
I wish you the best of luck and like always, Let us see some pictures!
kabarec
kabarec
Creative Director
That’s a good idea, probably should have thought of it sooner since the sun is going down
Some images of its current state. The drive modes I’ve tossed out the window and turned off stability, it wasn’t giving me all 4 wheels and felt like the front was digging even more…
Rivian R1T R1S Stuck in mud! Help pull me out -- ideas or assistance in Saugerties/Woodstock/Catskills NY area? IMG_3714
Rivian R1T R1S Stuck in mud! Help pull me out -- ideas or assistance in Saugerties/Woodstock/Catskills NY area? IMG_3712
Rivian R1T R1S Stuck in mud! Help pull me out -- ideas or assistance in Saugerties/Woodstock/Catskills NY area? IMG_3713
No_Name5330
Park City, Utah
Oh man! Seems like you could put a bunch of gravel in there and that may do the trick IF you could get it under the tires.
CBRacerX
You’ll need a lot of gravel. A lot. Probably more than you could easily get back there. Instead a shovel and clearing out a ramp where you are dug in, then using recovery boards are one way to self recover. A winched vehicle connected to a recovery strap attached to a hitch pin in the trailer hitch will get you out. Good luck!
kabarec
kabarec
Creative Director
Might try gravel tomorrow- tow companies close enough aren’t open or won’t do it… Rivian Roadside Assistance keeps sending me people 2-3h away for some reason, I know they are trying, but I also live 15min Kingston NY, seems odd they wouldn’t be able to find a recommended tow company closer to my location…
CBRacerX
I wish you well. If you can get some recover boards and shovel it will be some work - but you should be able to back out.
2x8 or 2x10 framing lumber can be used as recovery boards in a pinch. As mentioned above, digging out all 4 tires to create a gentle ramp and using recovery boards is the best solution. Been there, done that, got the muddy T Shirt.
Kitsap, WA
When life gives you soggy lemons, call a T-back tow truck. They'll rig you up, leap-frog their way to solid ground, then yank you out.
If you can’t get a tow truck there to help, I would use lumber and rocks/gravel to give those tires anything to grab. Bring a poncho.
Rivian R1T R1S Stuck in mud! Help pull me out -- ideas or assistance in Saugerties/Woodstock/Catskills NY area? 1724673941881-i2
