EveryAmp
EveryAmp
Atascadero, CA
everyamp.com
Rivian R1T, Tesla Model 3, & Model Y
3D-Printing
For those of us in front license plate required states, the factory front license plate mount requires drilling holes directly in the front bumper of the R1T & R1S. ? If you don't want to have permeant holes in your bumper, be sure to instruct your delivery advisor to tell your local delivery center not to drill your bumper. The OEM factory mount is installed at the delivery center and drilling of bumpers varies from location to location.
SnapPlate removable front license plate mounts install and completely remove in seconds without the need to drill holes in your bumper.
SnapPlate blends seamlessly with the front end of your vehicle and leaves nothing behind when removed.
? Introducing SnapPlate for 2025+ Gen2 R1T & R1S
  • Clean, minimal design blends perfectly with the Rivian front end
  • Installs and completely removes in seconds (see instruction guide)
  • Adjustable-height plate mount to reduce visibility on camera
  • Adjustable rotating latches to fine tune the fit on the grille
  • Breakaway features reduce risk of grille damage from minor accidents and car washes (remove for touch washes!)
  • Repairable and upgradable with low-cost replacement parts
  • Fits Gen2 2025+ Rivian R1T and R1S only (see our shop for other vehicles)
  • Fits US, Canada, and Mexico license plates only (see Custom SnapPlates for other countries)
  • 3D-printed with Made-in-USA recycled PETG plastic
** SnapPlate for the original R1 line is not compatible with the Gen2 R1 refresh despite how similar they look. Rivian changed the grille and bumper design ever so slightly.**
Rivian R1T R1S R1T/S Gen2 2025+ No-Drill Front License Plate Mount - SnapPlate | Removeable, Lockable, Height Adjustable, USA Made SnapPlate for 2025+ Rivian R1T & R1S Main Rivian R1T R1S R1T/S Gen2 2025+ No-Drill Front License Plate Mount - SnapPlate | Removeable, Lockable, Height Adjustable, USA Made SnapPlate for 2025+ Rivian R1T & R1S Features Rivian R1T R1S R1T/S Gen2 2025+ No-Drill Front License Plate Mount - SnapPlate | Removeable, Lockable, Height Adjustable, USA Made SnapPlate for 2025+ Rivian R1T & R1S Aesthetic Rivian R1T R1S R1T/S Gen2 2025+ No-Drill Front License Plate Mount - SnapPlate | Removeable, Lockable, Height Adjustable, USA Made SnapPlate for 2025+ Rivian R1T & R1S Adjustable Height Rivian R1T R1S R1T/S Gen2 2025+ No-Drill Front License Plate Mount - SnapPlate | Removeable, Lockable, Height Adjustable, USA Made SnapPlate for 2025+ Rivian R1T & R1S Design Rivian R1T R1S R1T/S Gen2 2025+ No-Drill Front License Plate Mount - SnapPlate | Removeable, Lockable, Height Adjustable, USA Made SnapPlate for 2025+ Rivian R1T & R1S Materials
ThirteenElectrics
R1S, R1T, XC40 Recharge
Does this mount screw up surround view like the factory one does? It sounds like it does.
beatle
Springfield, VA
Doesn't look like either plate screws up the surround view. Can you show what you're seeing? This is a larger version of the different views seen with the different plate mounts (OEM and the three SnapPlate mounting options):
Rivian R1T R1S R1T/S Gen2 2025+ No-Drill Front License Plate Mount - SnapPlate | Removeable, Lockable, Height Adjustable, USA Made 1721999717070-is
EveryAmp
EveryAmp
EveryAmp
Atascadero, CA
everyamp.com
3D-Printing
AS @beatle pointed out, no SnapPlate does not screw up the 360 view. It is slightly visible on the front camera depending on plate height. So is the factory drilled mount but they did reduce it's view on the Gen2.
Greenwater
Green
Tesla S
software engineer
That all sounds great, but I'd like to see the surround picture with it on in the various locations (so we can see the impact). The pics with just front view are good enough to get a sense about it.
EveryAmp
EveryAmp
EveryAmp
Atascadero, CA
everyamp.com
3D-Printing
Are you looking for something different from the surround view that's shown in the center column of this photo?
It shows the SnapPlate installed at 3 of the 5 different heights. You can always see a small dark rectangle and a sliver of the plate shows at the highest setting only. It's not perfect, but we're doing the best we can with what Rivian gave us to work with.
Greenwater
Green
Tesla S
software engineer
Duh! Sorry, that was what I was looking for. For some reason I thought the smaller pic that shows the surround pic somehow didn't look like a real surround pic but that is what I was looking for, sorry for missing that. Looks good.
Shaqdeez
Shaq
Buffalo NY
2024 Rivian R1S Glacier White /OC/22 Brights
No coupon for the RF folk?
Papi4baby
MD
Anyone taken their R1T on and touch car wash with the plate on?
I know they say to take it off, trying to see how lazy I can be ?.
EveryAmp
EveryAmp
EveryAmp
Atascadero, CA
everyamp.com
3D-Printing
I can say I have taken my personal SnapPlate through a touch carwash without incident a few times but they are all so different and known to occasionally take off side mirrors that we recommend removing SnapPlate prior to an automated touch car wash.
SnapPlate is designed to sacrifice itself before causing damage to your grille, unlike a metal option. If touch carwashes are important to you we can only recommend the factory riveted mount.
Hope that helps!
EveryAmp
EveryAmp
EveryAmp
Atascadero, CA
everyamp.com
3D-Printing
