RWerksman
Rob @ OSEV
Pittsburgh
opensourceev.com
Jeep & R1T & Silverado EV
Hello my dudes!
Allow me to introduce the new OpenSource EV Parts Seat Back Hanger. It's a super easy way to hang up to 5 pounds of dry cleaning, groceries, or whatnot on the rear of the driver and passanger seat in your Rivian. It adapts the stock tiny hanger on the back to a 40MM hook so you can hang items on it easier, without worrying about marring the seatback.
Rivian R1T R1S NEW - OpenSource EV Parts Seat Back Hanger IMG_1817_1807c758-527e-445c-a552-e98052828fa3
The product uses the same mounting plate as the Seatback Tablet Holder. A 40MM hook mount instead with the same M5 x 25 steel bot and low profile T-nut. As mentioned prior, it's rated to up top 5 pounds, despite being tested at over double that.
One of the awesome things is that if you already have a Seat Back Tablet mount, you can adapt it into this product by only purchasing the hook portion through our Replacement Parts area on the site, assuming you have a recent Tablet Mount without the Delrin pins.
Just to be really clear, these are absolutely not to be used when folks are in the backseat. I'm not even sure if it needs mentioned, but there you go...
These are priced at $13.95 each -- same as the Seat Back Tablet Mount. They are available now in limited quantities. You can purchase it here: https://opensourceev.com/products/seat-back-hanger
The retrofit kit for folks looking to convert their Seat Back Tablet Mount to the hanger is available for only $2.50. You can purchase it here: https://opensourceev.com/products/rear-seat-hook
The STL file so you can print one for yourself at little to no cost will be uploaded shortly to our Printables.com page here: https://www.printables.com/@RobOpenSource_519281/models
A video is also in the works and will be posted here when complete. for now - here are a few more pictures:
Rivian R1T R1S NEW - OpenSource EV Parts Seat Back Hanger IMG_1916
Rivian R1T R1S NEW - OpenSource EV Parts Seat Back Hanger IMG_1913
Rivian R1T R1S NEW - OpenSource EV Parts Seat Back Hanger IMG_1915
Autolycus
ATL
ICE only :(
I have one already. It’s a big improvement over the built-in hook for me. I’ve got an umbrella and a couple hats hanging behind the driver seat and they have stayed on the hook perfectly. A raincoat would also hang great, as would reusable shopping bags.
If you’ve got any of Rob’s other stuff, you know the quality of the designs.
That looks like it can take out an eye or a tooth. Don’t use it when someone will be sitting behind it, for sure.
Considering someone's dog had already sustained injuries to the factory hook, not just "someone".
RWerksman
RWerksman
Rob @ OSEV
Pittsburgh
opensourceev.com
FYI - The STL for this is now available on our Printables page - https://www.printables.com/model/613470-opensourceev-seat-back-hanger-for-rivian-r1t-r1s/files
We're at over 1,000 downloads from Printables!! Nice!
100% concur. This is not to be used while someone is in the backseat. There is both a message about there in the OP and one of the site.
