I don't really understand the people who ride on the 20's then worry about range. That doesn't make sense to me.
My Tri driving efficiency is far better than 2.1 or 2.3. Ambient temp typically 50 to 65 degrees. Mostly highway at 60 mph in Conserve mode. All Purpose used when climbing the incline from the highway exit to home at 1800 feet. 22 inch all season tires. The average on driving sessions typically of 58 miles is never below 3, and at times during the session is over 4. Based on the system learning my driving habits, on 100% charge the estimated range is within 2% of what was indicated on Rivian's web site. What this tells users is that wind drag increases significantly for each mph over 60 mph; AT off-road tires affect range from 10 to 20% depending on size, brand, weight and tread pattern; and that cold temperatures significantly impact battery efficiency and hence range. My experience with Tri R1T has been it lives up to the marketing on the Rivian web site. By the way, the 22 all season tires did great in Off Road Mode off-road north of Barstow, California. I was not surprised with the torque available and smart software. I encourage folks not to get wrapped up in the verbose nerdy minutiae of some YouTube videos that simply make you overthink and may misdirect purchasing decisions of people considering Rivian for the first time. The Tri R1T has exceeded all my expectations. Drive well.I am lazy today today so I will mostly post what I wrote in another thread that had the same vid.
“Well, for those that didn't watch the vid, the Tri Max barely got more range than the Gen1 quad and overall had worse efficiency. It only went 9 miles more with a 10% larger pack.
Both were wearing 20" AT Pirellis with similar conditions.
I should’ve added, 298 versus 289. Where are all the vaunted efficiency gains?”
That pretty much is my takeaway. I should have added efficiency of 2.1 vs 2.3. I could have spent 50k more on a new Tri and got 9 more miles. That is with a heat pump and a max pack… I think I made the right choice on passing on a Gen2 truck for now. Right for me anyway. YMMV of course.
And epa on gen 1 at is 270. That is what I have.The test seems pretty realistic to me as many people prefer to run all terrain tires for a variety of reasons. Kinda crazy that the test is so far from the EPA rating which I think is around 329-miles on 20" all terrain tires.
I guess it's just about 9% off from EPA rating which is not a 70-mph highway only test. The eye opener for me is how close the Gen 2 Tri-Motor Max Pack on All Terrain wheels is to the Gen 1 Quad-Motor on All Terrains; only 3% better for the Tri-Motor!
Is there an advertised mileage for 20" on conserve? I thought 371 is with the sport wheel/tires.It says 346 miles on full charge. If I get 298. That's great. However advertised mile is 371, getting 298 compare to 371 is bad.
You are putting way, way too much weight on the OOS Large range test.I think it's accurate. You can define "much" however you would like. Let me put it another way:
Rivian charges much more for the Max Pack Tri-Motor on All Terrains than the Large Pack Quad-Motor on All Terrains, however, the Max Pack does not drive much further than the Large Pack even though it costs much more.
Do you live at high elevation? That is the difference from what your experiencing.There is no way my Gen 1 R1T Quad Large on 20” ATs gets 289 miles at 70mph.
I wish it did, but it’s probably closer to 240-250 miles max, on a very good day.
Approx 1.8-1.9 miles/kwh at that speed * 130 kWh pack = 234 to 247 miles
All of this just shows how much nonsense OOS testing can be.
Thanks for setting me straight and explaining how aerodynamics and rolling resistance work. Please feel free to post your own testing procedures and results at your leisure.You are putting way, way too much weight on the OOS Large range test.
You hopefully know that at 70 mph aerodynamics and rolling resistance are the primary factors that impact range, and if you have the same body and same tires, you should get the same results. There is no way the Large Gen1 with the same aerodynamics and same tires is more efficient than the Gen2 Max. No way.
Worst case they are the same. But Gen2 does have powertrain efficency improvements so it might be measurably better at 70. Definitely not worse.
The OOS test of the Gen1 Large was a fluke. It should not be used to claim the Large is somehow more efficient than the Max at 70 mph. Such a conclusion defies logic, IMO.
Oh... I was talking about 22" range.Is there an advertised mileage for 20" on conserve? I thought 371 is with the sport wheel/tires.
Personally I compare them from a range perspective by comparing available battery capacity. When new, 10 kWh is the difference. So if you can get 2.1 mi/kWh in your R1, and assuming your battery SoH is 100%, you would go an additional 21 miles in the Max.Thanks for setting me straight and explaining how aerodynamics and rolling resistance work. Please feel free to post your own testing procedures and results at your leisure.
I think I will just keep my Gen 1 and forego upgrading to a new Gen 2 Tri-Max. My used Gen 1 R1T cost me $55k before tax, title, and tags. A new Gen 2 Tri-Max would cost me about $105k on the low side. It just does not seem worth it whether or not the OOS testing(s) had a fluke or possibly both tests were flukes.
Seems the Tri-Max is at best marginally quicker with marginally more range based on the only information available to me other than EPA testing done by Rivian.
I guess it depends on elevation, weather, and traffic conditions. I run 80-mile distances weekly at 70mph and see nothing less than 1.9m/k in 20-degree weather and 2.2m/k in summer with my quad with ATs.There is no way my Gen 1 R1T Quad Large on 20” ATs gets 289 miles at 70mph.
Good decision.. Keep your Gen1 QM. Also Tri Max is marginally slower and marginally same range when compare to Gen1. Don't make mistake of upgrading. I regret.Thanks for setting me straight and explaining how aerodynamics and rolling resistance work. Please feel free to post your own testing procedures and results at your leisure.
