it has wireless conductive charging per the website under "experience" in the info under the 1st pictureI've searched all the forums and haven't been able to find a post on this. Does anyone know if wireless phone charging will be available? If so, where? It doesn't look like there is anywhere on the dash for your phone.
The charging tray is the front part of the center console, not part of the dash.I've searched all the forums and haven't been able to find a post on this. Does anyone know if wireless phone charging will be available? If so, where? It doesn't look like there is anywhere on the dash for your phone.
Per the Owner's Guide:Can we settle once and for all of it charges one phone or two? I’ve seen conflicting info on this!
That doesn't really answer the question.Per the Owner's Guide:
I believe it does answer the question. Don't expect it to fast charge 2 phones simultaneously as it wasn't designed for that scenario and doesn't have the power to guarantee that usage.That doesn't really answer the question.
Does it actually work reliably? Or is it more like "yea the phones fit, but you're not actually going to recoup power faster than the phone uses it"?
You typed a lot of words to just agree with what I said: it does not answer the question.I believe it does answer the question. Don't expect it to fast charge 2 phones simultaneously as it wasn't designed for that scenario and doesn't have the power to guarantee that usage.
The answer isn't crystal clear because different phones will draw different power levels. Power consumption will also depend on what apps are running at the time, screen on/off, etc. Depending on the 2 phones involved, both may slowly charge if attempting to charge simultaneously (but more slowly than charging solo). Others may only balance out or slow the rate of battery drain. In other words, YCMV (your charge may vary).
The original question was can it charge 2 phones at the same time to which the answer is YCMV.You typed a lot of words to just agree with what I said: it does not answer the question.
It shouldn't be hard for Rivian to say how many Watts the coils support, what the total wattage of the system is, and how it handles a request for more than it can provide.
For example, 7.5W max per coil, 10W system max, power split evenly. Then we'd know two phones would only get 5W each.
Or 7.5W max per coil, 10W system max, left coil prioritized. Then we'd know passenger phone would only get 2.5W if driver was pulling 7.5W (which perhaps is the scenario if Rivian says two phones is not ideal but earbuds are okay).
Note: I'm not saying 7.5W/10W are the numbers... Just using those as theoretical values in the absence of any meaningful information, aka Rivian SOP.
It has been asked. It has not been answered.I have yet to see anyone pose the question asking for specific charging specs and the power distribution between coils. The unasked question goes unanswered.
