West Lebanon RAN Check-In Thread
cevans
C
Boston
2023 R1T Dual Max
Post your West Lebanon RAN Check-Ins here - success, failure, good tips etc.
Top tips:
  • If you are heading north the climb the last 30 miles will take up extra range. Disable preconditioning if you're low.
cevans
C
Boston
2023 R1T Dual Max
First time charging this weekend at below 0F. One charger offline on Saturday but on Sunday was working again. Sunday was the first time I've ever experienced a line, too.
If you're hungry the "Hungry Dumpling" shop with is just a few hundred feet from the charger has great Chinese noodles and dumplings. Beef Noodle soup and Pork Soup Dumplings are our go-tos!
RandomMcRandomFace
Boston
Volvo XC90, R1S
You had a line? Can you say what time? I’ve never had a line; curious what time one may arise (I am guessing prime return-from-skiing time).
Very cold battery (even with 45 minutes of preconditioning) and so I was stuck at 100kw for a bit and then I bounced around speed wise. i feel like cold is such a challenge for these cars.
cevans
C
Boston
2023 R1T Dual Max
Friday night no line but all chargers were full. Sunday afternoon around 2pm was all chargers full and a line up which was as high as three.
The 100kw limit was across all chargers, but I chalked that up to all the chargers being in use and the shared 300kw. I did notice that, once it freed up, some Rivians were going to 175 and then down to 100 repeatedly.
doit82
Vermont
Model Y, R1T
Never had a line charging here on my way to/from boston from burlington vt.
Word of caution, be careful if you are traveling north from boston to charge here. Believe the navigator. Due to the cold and sharp elevation change in the last 30 to 10 miles approaching the charger I was down to 1 mile per kw and ran out of battery and ended up having AAA get me a tow the last 10 miles to this charger. I didnt believe the navigation that I would burn through 50 miles in the last 25 miles to get there, but that is what i did and then some. It is all down hill the last 8 miles or so, so i was probably only a few miles off from being able to make it, but was not worth it and there is nothing even in the level 2 range for about 50 miles before lebanon.
cevans
C
Boston
2023 R1T Dual Max
Working great today. Three charging.
Rivian R1T R1S West Lebanon RAN Check-In Thread IMG_1219
147 kw.
md2023
New England
Subaru
Perfectly located for a trip from MA to Burlington. Stopped each way. fast, easy and not cheap (but worth it).
PeterSK
Peter
Cambridge, MA
2023 FG/FE R1S, 2021 Model Y
Retired / board director
Charging at the EA station by Walmart. The NAV directed me here, though it also showed RAN available so we got Panera to go only to discover the RAN down.
Talked to a tech with an R1T and equipment mounted on back. He said they just finished upgrading the pedestals and need about two more hours to push through the software updates. So open about 3pm or later today, May 20.
This means other CCS cars and Teslas with adapters will be able to use our measly 6 stalls? Not looking forward to that on weekends.
Lars24
Vermont
Confirmed, they are up and running now with the new pedestals.
edit: $0.41/kWh for Rivian, $0.54/kWh for other. Not obvious from seeing pictures of the updated dispensers, but they are considerably taller than the originals.
PeterSK
Peter
Cambridge, MA
EA station charged $0.48/kWh and is near more food and shopping options, so hopefully that will keep the RAN from being overwhelmed by non-Rivians.
PeterSK
Peter
Cambridge, MA
Just charged at the RAN. On the way up Sunday afternoon all stations were briefly occupied, including a Bolt EUV and another GM (Equinox?) at the pull-through stall. It was only five days from the installation so I asked the EUV driver how he learned of it - Plugshare.
Today on the way back South we were the only vehicle for most of our charge. A G2 Forest Green R1S arrived shortly before we left.
Rivian R1T R1S West Lebanon RAN Check-In Thread IMG_3312
