strykerwsu
Kansas
Quite a lot to update but currently working on adding some Morimoto lights to my Xtrusion Overland bed rack.
Amber spot chase light and some "scene" lights. I've also gone from 4 bangers to 2 bangers for ditch lights. That way I don't get any light bounce on bumps and while offroad. Went from s00nish ditch light brackets to some from M&R that I had to modify.
I have the light wiring harness built for the rack and now I need to drill through the small corner panel by the rear window to get my wires into the cab. I will be using my existing grounding block behind rear seats (using for WeBoost and Midland GMRS radio) and pulling power wires all the way through the firewall and to my Garmin PowerSwitch in the frunk area.
More photos when all is completed.
And a beauty shot just because. :cool:
Any additional pics of where you drilled for chase lights and how you ran wiring in the rack?
WattTruckMatt
WattTruckMatt
Austin
2022 Rivian R1T
I drilled through this small plastic piece. You can see where I made a mistake the first time around. I'm an idiot and should have known the tonneau cover "box" was under there. I measured a few more times to find a small gap under a plastic to run the wiring to a grommet behind rear seats.
I'm about to get a tonneau replacement and I've already purchased a replacement piece so I'll have them do that in a few weeks.
I will need to remove my bed rack and which point I plan to update the wiring a little bit. I'm going to run my GMRS and WeBoost Antennas through this hole as well.
Rivian R1T R1S WattTruckMatt's El Cap Granite R1T Journey & Build Journal Screenshot 2024-03-03 at 8.33.58 PM
strykerwsu
Kansas
Thank you. Which size drill bit grommet and where did you get it, if you remember?
Also, I’m almost always that idiot as well lol, I feel your pain. Cutting into my frunk to add the 12 volt today made me pucker.
WattTruckMatt
WattTruckMatt
Austin
2022 Rivian R1T
WattTruckMatt
WattTruckMatt
Austin
2022 Rivian R1T
Some pics from this past year.
Offroading in Central TX
Rivian R1T R1S WattTruckMatt's El Cap Granite R1T Journey & Build Journal 1C230F17-9AB2-4124-8C0E-373ADC7D0493
Rivian R1T R1S WattTruckMatt's El Cap Granite R1T Journey & Build Journal 2C5A064B-B8D2-4BAD-8ACE-C7139728CC21
BBNP
Rivian R1T R1S WattTruckMatt's El Cap Granite R1T Journey & Build Journal 4C540D1F-7C86-4195-9B81-D62F9DA5E434
OEM sized BFG KO3s
Rivian R1T R1S WattTruckMatt's El Cap Granite R1T Journey & Build Journal 472DBFA5-7165-465E-B615-601B455D0AC8
EV Sportline Carplay Screen
Rivian R1T R1S WattTruckMatt's El Cap Granite R1T Journey & Build Journal BB133965-E27A-49BA-A850-B5AC03EE9217
Morimoto Rock Lights
Rivian R1T R1S WattTruckMatt's El Cap Granite R1T Journey & Build Journal E2C37030-86D8-482F-8F6D-A3883E3CA11F
BestEvMod Floormats
Rivian R1T R1S WattTruckMatt's El Cap Granite R1T Journey & Build Journal IMG_5550
GOAT Fabrication Sliders
Rivian R1T R1S WattTruckMatt's El Cap Granite R1T Journey & Build Journal IMG_5622
Did a little towing
Rivian R1T R1S WattTruckMatt's El Cap Granite R1T Journey & Build Journal IMG_6255
Rivian R1T R1S WattTruckMatt's El Cap Granite R1T Journey & Build Journal IMG_6796
Hill Country
Rivian R1T R1S WattTruckMatt's El Cap Granite R1T Journey & Build Journal IMG_7031
WattTruckMatt
WattTruckMatt
Austin
2022 Rivian R1T
Do you have more info about your mounting and wire routing for the rock lights?
  • The lights are mounted with the included magnets.
  • I kept the plastics off when I mounted the sliders which gave me some mounting options.
  • There are channels under the truck where I was able to snake the wires through to the front just before the fender liners then I fished them up to the frunk area (under trim that hides the 12V battery compartment).
  • Originally, I was going to use 3 per side, but that ended being a lot and more cumbersome with the wiring. There also weren't many options to mount the lights after the rear tires.
Rivian R1T R1S WattTruckMatt's El Cap Granite R1T Journey & Build Journal IMG_6210
Rivian R1T R1S WattTruckMatt's El Cap Granite R1T Journey & Build Journal IMG_6211
