Supratachophobia
I got 2.35 on a 267 mile round-trip in the same day. So yeah pretty normal.2.38 mi/kWh
Isn't that pretty much par for the course in the R1S?
Hey, I got 2.4 for many miles on the interstate in my LE R1T w/20-ATs!I'd take that all day long with my LE R1T
2.38 is pretty decent for a vehicle of this size.2.38 mi/kWh
Do you have a full electric drive-train or is the engine connected to the wheels?It's amazingly efficient when you compare it to my Wrangler 4xe that weighs 5,100lbs and goes only 23 miles on a 15kWh (usable) battery for a "worst in class" efficiency of 1.5mi/kWh![]()
Think of a standard ICE vehicle arrangement ICE connected to an 8-speed transmission connected to a rear differential, then add an electric motor inside the 8-speed transmission. That's how Jeep does it in the Wrangler 4xe. So it's a completely conventional drive train except for the electric motor inside the regular 8-speed transmission.Do you have a full electric drive-train or is the engine connected to the wheels?
At least after things warmed up. My truck sucks for the first mile when cold. I typically go up a hill for the first mile when I leave my house and it isn't huge. Maybe up 100' or so.The answer is the climate control. I would preheat my vehicle in those temps and drive to the gym with only heated seats and steering wheel on and get close to 3.5 miles/kwh
Climate control will kill it, especially if it’s blowing heat. I guarantee you if you had climate off you’d be getting 3+ mi/kwh assuming no strong headwinds on mostly level ground.
I can get 3 mi/kwh (or better) in my Cybertruck AWD in the same conditions.2.38 is pretty decent for a vehicle of this size.
Were you running the heat in the CT? I am getting 3-3.5 mi/kwh in the same conditions you are. Not running hvac.I can get 3 mi/kwh (or better) in my Cybertruck AWD in the same conditions.
What's the adjusted efficiency to account for the stainless steel panels remaining attached to the vehicle for the entire trip?I can get 3 mi/kwh (or better) in my Cybertruck AWD in the same conditions.
Don't recall, both vehicles were at 72 auto and low fan speed. I rarely change it.Were you running the heat in the CT? I am getting 3-3.5 mi/kwh in the same conditions you are. Not running hvac.
Well that's a big difference....running resistance heat will absolutely drain at least 1/2 a mile per kwh. It's one of the single biggest consumers of energy outside of driving. There's your answer. I just drove my R1T dual motor today and was getting 3-3.5 mi/kwh driving around town with no HVAC on.Don't recall, both vehicles were at 72 auto and low fan speed. I rarely change it.
Not really. I pre-conditioned the R1S for 30 minutes before departure and it was low to mid 50's outside so it wouldn't take much energy to maintain temp with the sun load during the day.Well that's a big difference....running resistance heat will absolutely drain at least 1/2 a mile per kwh. It's one of the single biggest consumers of energy outside of driving. There's your answer. I just drove my R1T dual motor today and was getting 3-3.5 mi/kwh driving around town with no HVAC on.
