dp351
Ariel Atom, R1T
I’m considering getting the same wheels that @OffRoad987 showed above (20x9”, +25 offset) with 285/60 or 295/60 tires.
According to this source, compared to the OEM 275/65/20’s, 295/60’s would be 0.2” shorter and 0.8” wider, and 285/60’s would be 0.6” shorter and 0.4” wider.
I suspect that these would rub in lowest ride height while turning sharp and perhaps under full compression, but I wouldn’t drive it in lowest with tires this size.
I’m curious if anyone has tried either of these combos, or has any useful thoughts about them
dp351
Ariel Atom, R1T
Update: I have the new wheels & tires installed. I have the wheels described above (20x9”, +25mm offset), with 285/60/20 BFG AT KO2 tires.
@Rexbo For the table at the beginning of this thread- After driving this setup a few hundred miles on the street, I’ve had the front tires rub in low & lowest ride height over bumps, with the suspension in Soft. There’s no rubbing in full lock turning without bumps. In medium ride height, I have not experienced any rubbing so far.
Rivian R1T R1S Tested 35" tires on the R1T - for offroading / overlanding C4C67AFE-E199-4BD1-97EA-D6EDA3474719
Jayhawkeye
Kansas City
Ford Expedition, Jeep Grand Cherokee
Software
Someone please post pictures of these badazz tire/wheel combos on a R1S! Now this is a look I could go for when we (eventually) get our rig!
Brewbud
@Rexbo Here’s another combo for your table:
OEM wheels (powder coated) with 285/65R20 Nokian Outpost AT. No rubbing and overall a great tire.
Looks great. Curious f those would rub when turning while flexing in an offroad situation. Can you post a full side profile pic when you get the chance?
Desiboy
Tesla Plaid, LR4 ‘11, R1S
Picked my R1S last Friday. Quite like it. I've had an LR4 on which I put BFG KO2s 33.1" tires tho it required a heat gun and some banging, rolling. Reluctant to do that again. Rexbo, how are the 34.6 (285/65/20) working out now that you've put some miles on them? What rubbing issues? Esp offroad?
uthatch
Uri
Model X Plaid, Model Y, Bronco - sold for R1T
R1's really wear matte finish so well! And then the tires look great too. Nice truck!
TXR1S
TX
R1S on order
No rubbing on lowest? Very curious if you notice any range impact with these, just a hair bigger and wider than OEM but look great.
oybed
2022 Rivian R1T, LG, LE, BM, 20" AT
No rubbing yet, and there's quite a bit of clearance on the lowest so I expect it to be fine. But, I got them installed not long ago, so I'll report back once I have put them to the test - including any sort of range impact. Will know more s00n.
seanocono
Sean
LA
Tesla Model X Plaid, Tesla Model Y Performance
here you go - both standard and high setting
Awesome looking truck! I really like the powder-coated wheels, beefier tires, and matte wrap on the Launch Green. It all looks especially nice in this light. Enjoy it!
MaskedRacerX
DT
Vilano Beach, FL
'21 Tesla M3P / '21 Jeep Wrangler 4xe
Software Dev / Architect / Product Designer
I know most of this is a discussion about capability improvement, but wow, do those bronze wheel over the yellow calipers on the red truck look fantastic.
Rexbo
Rexbo
@oybed Updated table, thanks! That satin wrap is some hotness!
@dp351 Updated table, thanks! Color combo looks excellent, got that iron man look.
@Desiboy Honestly, I drive most of the time in normal ride height in soft, and it takes a BIG bump to get them to rub, so really at this point I don't have any complaints. That said, I did put the stock 21"s back on because they're quieter and better efficiency, and will just be swapping back and forth for camping trips.
Inkedsphynx
+1 interested in your findings. Those are a great looking tire on the truck. I try not to fall too hard for aesthetics when making overlanding decisions, but I've not seen many that fit better and have that nice a look, thus far.
