dduffey
- Thread starter
- #1
I have an existing Tesla GEN 2 HPWC running at 40a and using a Lectron Tesla to J1772 adapter also rated for that. I noticed when I plug in the R1T ring is white, then goes red for a bit and then goes green (charging). It doesn't pull more than 10kw.
Asking to see if others noticed the same on non Rivian chargers. (I am using my existing setup because I have load balancing HPWCs).
Also one time I noticed checking the app that the R1T said "charging has reached set limit" but it had not. When I went outside I noticed the HPWC had to be reset (no lights). That had never happened before.
Lots of variables changed though, for example now using the adapter and the cable is now outside where the cable+handle is getting direct sunlight and gets hot (I charge the Teslas in the garage).
Posting in case others have noticed similar behaviors. I am not too concerned, just need to check that charging is initiated after plugging in now.
