Tesla charging membership setup
paranee2
Parani
Canada
Hi,
Quick question: I enrolled in the Tesla charging membership through the Tesla app using the same email as my Rivian account. When I tried using one of the Tesla chargers, my R1S started charging immediately without letting me choose on the Tesla app. In the end, I received an invoice from Rivian with a non-membership charging rate. Am I doing something wrong?
emoore
Hi,
Yes. You need to start the charge in the Tesla app before plugging it into the Rivian.
paranee2
Parani
Canada
Thank you I'll try tomorrow
Electrified Outdoors
Mount Airy, Maryland
www.ElectrifiedOutdoors.com
2024 Rivian R1S Quad, 2024 Silverado EV RST First Edition, R2 Reservation
Real Estate
This is how it works in case your curious. Plug and charge bills through your Rivian account at the regular non-member rate. Its like the magic dock chargers when you activate for a non-tesla.
lightsgoblack
C
Rivian R1S, Tesla Model Y, Ford F-150
(DO NOT PLUG ANYTHING IN YET)
1. Open Tesla app
2. Top right 3 lines menu
3. Charge Your Other EV
4. Select your station/charger, press start charging
5. Connect adapter and plug in
When you’re done, you can stop charging from the Rivian app if you want.
If you don’t follow these steps, you’ll be charged through Rivian at non-member rates.
Good luck!
kozak79
New Jersey
www.youtube.com
Visual Effects
You can remove the payment method from the Rivian app (in account section) so it doesn't happen by accident. Otherwise Rivian will start charging using the payment in the Rivian app.
moosetags
SuEllyn & Brian
Santa Rosa Beach, Florida
Can you easily turn on and off the Tesla Membership like on EA? I would use Tesla Superchargers only while on road trips.
AARivian48
Alaa
Knoxville, TN
Forest Green R1T Adv. / BM / 20 AT
management
I wish I saw this post yesterday. lesson learned . thank you for all the info
NC-Rivian
Greg
Hendersonville, NC
LA Silver R1T; Blue R1S
Yes. On/off is easy. Payoff is approximately 110kw which is pretty easy to meet in the span of a month.
goodoljake
Too many
So do we have to pay the $13 a month to use the Tesla app billing? I don't see a way to charge or select a station in the app at all and don't have the paid version.
DeafPug
Kansas
'18 Model 3, '22 R1T
To use the Tesla app to charge your Rivian, you use the hamburger (3 lines) menu in the top right of the app, then select Charge Your Other EV. From there, select the Supercharger from the map and the Charge Here. To use the Tesla app and discounted pricing, you must initiate the charging session from the Tesla app BEFORE you plug into your Rivian.
The only reason to use the Tesla app instead of the plug-and-charge feature with billing through Rivian. If you don’t have the Tesla membership, you pay the same price for charging no matter if you bill through Rivian or use the Tesla app. The only way to get the discounted membership pricing is to initiate the session with the Tesla app.
goodoljake
Too many
dang, thank you. i got it now. i was looking under charging and not at the bottom of the page.
paranee2
Parani
Canada
Thank you all for the information. I made a mistake. I chatted with Rivian customer service, and they told me to just plug it in with no need to use the Tesla app. They said my Tesla account, which is linked to the same email as my Rivian account, would automatically adjust. However, that was incorrect. I tested it by just plugging in and noticed I was charged at a non-member rate. After receiving advice from "emoore" on the Rivian forum on how to use it, I tested it again the next day, and it worked. The only issue is that Canadians are facing a problem where the Tesla app forces them to use a U.S. address before enabling the charging button. I used my sister's address in the U.S., and it worked
jamesphw
Canada
Mustang Mach-E
I'm in Canada and set up my Tesla account with a Canadian address... I didn't have any problems enabling Tesla chargers from the app. Not sure why you had to you use a US address...
Incidentally, it is the same with Ford: you have to use the app to start the session, not plug & charge, to get the membership pricing.
RivAW
Alex
MA
Yes but the membership is for a month at a time…so if you shut it off, you don’t get a pro-rated refund, and retain access to the member pricing until the end of your membership month
