The question is how did Zack's video propagate to the person that wrote the patch notes?There should be a dedicated bug report and feature request ticket types/system for sure.
I thought it was somewhere around 40-45 degrees based on my own observations of efficiency (mi/kwh) - drain would be a bit lower on my own observations as wellI’ve collected some data that also suggests this. There is a lot of scatter in the drain rate but the distribution is bi-modal, splitting somewhere between 30-40 deg F. Good to see others are noticing this too.
I was told that they forward that info to the dev teams from the service team.The question is how did Zack's video propagate to the person that wrote the patch notes?
What kind of range are you seeing with 20” AT after the update??Release notes. Just completed installation.
201 @ 70% generates 287 @ 100%.What kind of range are you seeing with 20” AT after the update??
Hit reset history201 @ 70% generates 287 @ 100%.
Where? App or UI? Haven’t played with it since the update.Hit reset history
Its in the energy menu in the UIWhere? App or UI? Haven’t played with it since the update.
Improved EPA – Estimated Range Numbers
Thanks to various incremental improvements over previous software updates, this update includes updated EPA-estimated range. The update also increases the depth of discharge, which increases the usable battery energy. You see higher available miles at the top of charge and efficiency update in the efficiency graph and trip computer.
NOTE: Reset the range history first for your vehicle to reflect the updated estimated range numbers.
To reset range history, on the center display, go to Vehicle > Energy > Range based on > Reset History.
Go to the charging icon (lighting bolt). On left side hit the area showing what mode you are in. Brings up screen showing range in all 3 main driving modes. At bottom hit reset historyWhere? App or UI? Haven’t played with it since the update.
But I would have to get up out of my La-Z-Boy to do that!Go to the charging icon (lighting bolt). On left side hit the area showing what mode you are in. Brings up screen showing range in all 3 main driving modes. At bottom hit reset history
