Snow / ice chains on a quad R1T?
llcsf
Larry
San Francisco
can you use snow/ice chains on a quad R1T
Tarkus
Robert
'06 Lincoln Mark LT
Outdoor/Indoor E911 Wireless Engineer
I've bought 2 sets of these for my upcoming E911 Wireless Drive Testing work assignment in the 9 New England states starting in a month.
K&K Automotive Snow Socks for Tires - Pro Series for Ultimate Grip Alternative for Tire Snow Chain - Snow Traction Device for Light/Semi Truck Pickup SUV Winter Emergency Accessory European (XX-Large)
(Snow driving only, no asphalt) :cool:
Rivian R1T R1S Snow / ice chains on a quad R1T? 20230807_090628
Cycliste
Solano County, California
Amateur aero weenie
SkiLizardHead2
Stan
SW Colorado
MX, M3, 4Runner, FJ60, GTO
Retired Aero Engineer
you really don't need chains/cables or snow socks if you have a good set of snow tires like Michelin X-Ice.
Cycliste
Amateur aero weenie
I don’t plan on ever using my AutoSocks. I just have a pair in the truck to comply with the law in some areas in California.
tragicmonkey049
Erik
Chelan County, Washington
2023 R1S Adventure; 2019 Toyo Prius
Curmudgeon
Anyone else curious if they just forgot to update the manual after adding snow mode?
I don't think they forgot. Snow Mode actually puts the vehicle in Low Ride Height at freeway speeds (owner's manual, p126), shrinking the clearance between wheel and wheel well. If you chain up, you need *more* clearance around the wheel. No matter how tight you get those cable chains, at 30 mph, those cross cables or chain segments are flinging tall as they come over the top of the wheel.
The 275/65 tires probably (someone looking at this surely knows better than I) have less inside clearance between tire sidewall and strut parts inside the front wheels, too, hence the restriction specifically for that size.
This company makes pretty skinny chains, and they still require 0.59" of sidewall clearance for their skinniest LT chains. I stuck my hand along the inside sidewall of the front tire of my R1S with stock 275/65 Scorpion AT tires and I don't think there's enough room in there.
Plenty of room in the back though, so I'm going to try some "S" class chains on back only and see how it goes...
