Foobar
Out and about
R1T, Model 3P, Eva Ribelle
IT Exec
My electrician hardwired, but did 40 / 50 just because of parts. I have no idea how this all works, but I'm getting about 19-20 miles an hour. Any discernable benefit to go to 48/60?
48 amps will get you around 25 mph I believe.
Lens
Jay
Hawthorn Woods, IL
Palisade, Kia Sedona
I am getting consistent 29-30 miles per hour of charging with 48/60 setup
Baldewin
The Orange Curtain
Images when I was rapping up my installation. The DPDT safety switch allows me turn off the charger if I'm gone or allows me to use the circuit for my welder.
Rivian R1T R1S Show off your Level 2 Home Charger installs here IMG_4185
Rivian R1T R1S Show off your Level 2 Home Charger installs here IMG_4184
Lil'Dave
Central IL
R1S LE
Product Support
Tesla J1772 charger. 24' cord. Easy install to replace the identical (except for cord) Tesla charger I had before.
Rivian R1T R1S Show off your Level 2 Home Charger installs here IMG_0742.JPG
Snazzy Labs
Quinn
Salt Lake City
Rivian R1T, Genesis GV80, Coda EV
YouTuber
48A OpenEVSE I installed myself. Unit is small, software is great, hardware is open source and completely repairable from a component level, and the cable is excellent. So flexible and never tangles.
Rivian R1T R1S Show off your Level 2 Home Charger installs here IMG_3262
Rivian R1T R1S Show off your Level 2 Home Charger installs here IMG_3239
Rivian R1T R1S Show off your Level 2 Home Charger installs here IMG_3325
abirozy
southern california
tesla model s, lexus gs 350 f sport, toyota corolla
lawyer
Here was how I configured my setup.
Installed the Rivian charger hard wired via 6ga cable (very small run to my panel) using a 60amp breaker.
Then mounted a place to store my cable closer to my garage door which I cut a hole through and installed a cap/door as a cable pass-through. (I also created an insulated foam plug to go into the cap when I'm not using it)
So now when I want to charge the truck I just pass the cable through my garage door. When I'm done I put it all away. 👍
This looks like a very clean setup. My only concern would be my daughter opening the garage door when the cable is run through for charging.
michaelcasto
Michael
Winston Salem,NC
R1t
Landscaper
Getting excited for my R1S and it will be the first EV I have. I'm torn on if I should hardwire (for max amps) a charger in the garage or outside around the corner. It really depends on if the R1S will fit in my garage or not.
Anyway, I tend to have a lot of outdoor tools lining the sides of my garage and a large wood set of shelves in the back so looking for inspiration on clean installs for charges in the garage and thought it would be great to have a compilation of them here. Doesn't matter if it is the rivian charger, plug in, hard wired, etc.
I park outside the garage since wife has the one garage spot. 😂 so mine is outside some of us have to rough it.
Rivian R1T R1S Show off your Level 2 Home Charger installs here BFA53794-1644-4E34-8A47-B896CE92C025
Rivian R1T R1S Show off your Level 2 Home Charger installs here 35888A02-1092-46D4-B76C-0B12EE933DF2
redantpile
allen, tx
2018 EDGE, 2023 R1S red adventure 20"
Retired telephone engineer
Finished this a few weeks ago. I should get my R1S this Thursday. I wanted a receptacle in that corner so I ran 1" liquid tight with 3 x #6 and 3 x #12.
A couple of things about the charger. People have posted about turning off the 5 ghz to get it to connect to wifi. I did not have to do that. My SSID is the same for both and I just turned off broadcasting the 5 SSID. I also have a Guest wifi and also had to turn off that 5 SSID, even though the charger was not using that Guest network. Everything connects just fine after that and my 5 ghz devices still connect just fine. If that helps anyone.
Second thing. If you decide to play around with the ethernet port, be careful removing the cable. Mine would not release when pressing the tab for some reason. I removed the front plate for easier access. To be clear I have decades of experience with rj45's, ethernet cables etc.. I pulled the jack completely off of the board. I did not pull too hard. I suspect the two solder points on each side were not done properly. Could be just my charger but FYI.
I can't try the charger yet but it seems to be working fine.
Rivian R1T R1S Show off your Level 2 Home Charger installs here 20230525_130257
Rivian R1T R1S Show off your Level 2 Home Charger installs here 20230603_152549
Rivian R1T R1S Show off your Level 2 Home Charger installs here 20230525_130319
Rivian R1T R1S Show off your Level 2 Home Charger installs here 20230603_152619
Ingo B
Word Slinger
Got a local electrician's help on this one (upper left in pic). Electrical scares me. Despite my best efforts, the garage is officially out of space.
Rivian R1T R1S Show off your Level 2 Home Charger installs here charger-garage
Sevn86
2018 Range Rover Sport HSE
Jumpman
Richard
Rocket City USA
22 R1T LE, 16 Boxster GTS
Now this is interesting! I'm anticipating having a Tesla to go with my Rivian eventually and I would rather not use adapters on a regular basis, but I don't need to charge both cars at once. So I was thinking of installing 2 chargers which could be selected using a switch such as this:
https://www.amazon.com/gp/product/B07H5GZ53G/ref=ox_sc_saved_image_1?smid=A3HMB6GLG0WJ17&psc=1
Rivian R1T R1S Show off your Level 2 Home Charger installs here 51KQOaSn9UL._SL1200_b
What you have looks a bit more ... heavy duty, though!
