Will I get a faster charge with a 60-amp circuit hardwire? Rather than a max 50 amp?I'd suggest to check if hardwire the charger instead of an outlet is better. You can do a 60amp circuit hardwire (instead of max 50amp on receptible), its cheaper (receptacle requires expensive GFCI breaker), plus there are fewer points of failure.
I know in my garage a major part is figuring out how you will most often park the two vehicles and where the charge ports are and then the best spot for a charger.
Installing two Tesla Wall connectors have good power sharing options.
Yes, the car will pull 48 amps on a 60amp circuit vs pulling 40 on a 50 amp circuit.Will I get a faster charge with a 60-amp circuit hardwire? Rather than a max 50 amp?
Remember that the actual current delivery should be limited to 20% under the circuit, so if you have a 60-amp circuit, you would de-rate your charger to draw 48 amp maximum. 40 amp for a 50 amp circuit, etc.Will I get a faster charge with a 60-amp circuit hardwire? Rather than a max 50 amp?
You can only use 80% of the rated capacity. So a 60 amp circuit can give you the full 48 amps that a Rivian can take. A 50 amp circuit can do 40 amps if hardwired but most non-hardwired chargers will actually only let you do 40*.8=32amps because 40 amp circuits use the same plug so the charger can't be sure if it is plugged into a 40 amp or 50 amp circuit. to be safe, it assumes the lower.Will I get a faster charge with a 60-amp circuit hardwire? Rather than a max 50 amp?
Yeah if your charging overnight anything 240 volts will be fine.My Rivian and Tesla are sharing a single 30A*240V circuit.
Usually we just alternate and plug each one in every other day, although the car that is plugged in usually full before bedtime so we could switch the charger over to the 2nd car if we really need both to be completely full in the morning.
Yeah, a quality receptacle is a must. Seen dozens of melted ones because they were the cheap home Depot ones for an oven not an EV charging non-stop for 8-12 hours. Oven/dryers/etc all cycle on and off which is far less stress on the house electrical system.Remember that the actual current delivery should be limited to 20% under the circuit, so if you have a 60-amp circuit, you would de-rate your charger to draw 48 amp maximum. 40 amp for a 50 amp circuit, etc.
And hardwire is absolutely safer than plug. The industrial NEMA 14-50s are significantly better than the dryer ports, but even then - go hardwired if you can.
Yes, very accurate! I work at home, so I don't travel that muchYou can only use 80% of the rated capacity. So a 60 amp circuit can give you the full 48 amps that a Rivian can take. A 50 amp circuit can do 40 amps if hardwired but most non-hardwired chargers will actually only let you do 40*.8=32amps because 40 amp circuits use the same plug so the charger can't be sure if it is plugged into a 40 amp or 50 amp circuit. to be safe, it assumes the lower.
So yes, hardwired to 60 amp circuit is significantly faster than a 50 amp plug. 50% faster.
But how much do you actually need? How much do you typically drive in a day?
Does it really matter if you finish charging at midnight or 2:00am? As long as you're full before you wake up, the extra speed is not going to be noticed.
If you expect to frequently return home with a completely empty battery and need it to be 100% full before you wake up so you can drive 300 miles again the next day, then you should get as much power as you can. But most people don't do that and even a much lower powered circuit will be more than enough to replenish overnight what you use on a typical day.
checkout neocharge. That’s what we use for our model Y and R1T on one charger.Does anyone have recommendations for a dual EV charger that can efficiently charge both a Mercedes EQB and a Rivian R1S? If I were to go with just one charging station, any suggestions? I’ll be installing a 240V outlet in my garage.
