Roomy Access not restoring post .38.0
atebit
R1T, Porsche Boxster
With Roomy Access enabled, my seat moves to the Comfy Access position when I park the truck. But since the update, the seat fails to return to driving position the next time I get in & hit the brake probably about 75% of the time.
Anyone else?
Rknb2000
Richard
Georgia
2023 Rivian R1T
With Comfy Access enabled, my seat moves to the Comfy Access position when I park the truck. But since the update, the seat fails to return to driving position the next time I get in & hit the brake probably about 75% of the time.
Anyone else?
I have noticed if you unlock your vehicle with the key Fob it won’t recognize my setting. It only works with my phone as a key, in my case.
racekarl
MA
That at least may be working as expected if the fob is not assigned to your driver profile.
Rknb2000
Richard
Georgia
2023 Rivian R1T
The Fob is assigned, but works when it wants to.
AlexF
Alex
Colorado Springs, CO
Tacoma, BMW
Computer Systems Validation Engineer
If you push a steering wheel button before or during the seat movement back to your normal position it will stop the process and then won’t allow you to restore it back to your normal position.
Seems like a SW issue with an interrupt routine ?
gsqrd
saratoga ca
2012 infiniti G37 convertible, 2010 expedition
retired computer designer
Exactly the same circumstances and behavior. R1S
We have two fobs, both assigned to different drivers, neither adjust the seat when they are used. We do not have easy access set but if my wife drives the next time I drive with PAAK, the seat adjust to my position when I open the drivers door.
atebit
atebit
I’m exclusively PaaK, should’ve mentioned that.
jfornelli
Jason
RAM 1500, Tesla Model Y
I'm having this same issue in my R1S. Since the last update, sometimes it works, sometimes it doesn't.
Firstlast
Same behavior since latest update. Comfort access and proximity unlock have been 70% reliable
TheIglu
Clayton
North Central MA
2022 Rivian R1T
Same experience. Kinda frustrating.
Though generally, I always do a full reboot after software updates or I see issues like this. Haven't done so yet, but will next time I drive and I'll report back if it helped.
Generally speaking, the Comfy Access isn't very reliable if you walk up to an unlocked (while at home) truck that's been sleeping and open the door/jump in. I usually have to tell it to restore my settings in that situation. It's like the system needs time to wake up before it'll properly activate the "return to driving position" command when the brake is pushed.
Kitsap, WA
Anyone else?
Yes! I thought I was getting shorter. Exclusively fob use. It reset a few other settings like wipers and drive mode too, really bugs me that it inconsistently changes defaults or fails to restore fully after an update.
