astonius
Ah, I thought the divot at the front of the handle was a capacitive touch button.Same for me, but there aren't any buttons on these doors.
That’s not an R1.Saw this posted. Gear guard security footage not mentioned … might have caught the perpetrator. Feel bad but I also fear the R1T is going to draw the same Tesla jealousy/spite in public for awhile until they become more commonplace.
I expect OTA updates to resolve some (but not many) of the issues raised in this forum and elsewhere. My real hope is that mid-2021+ preorders will end up with some improved components, but I'm not counting on it.Well there goes that idea. It could all be different by the time of my delivery though (Oct 2021 Max Pack pre-order). Though I must say I'm not putting faith in OTA updates to fix every short coming like it seems is the common response.
Does this mean that if my R1 is plugged in charging in my garage and I want to leave to run an errand, I first must get in the car, find the Energy menu, press the stop charge button, get out of the car, remove the plug, hang up the plug, get back in the car, and then I'm finally allowed to drive away?Stop a charge session as follows:
1. Go to the Energy menu.
2. Select Stop Charge.
3. Press the button on the plug handle and pull on the handle to remove the charge cable.
4. Return the plug to the charger.
God, I hope not. There should be a button you can press on the exterior to end the charge and release the plug. That would be a seriously annoying miss. If so, I'd at least hope the app has a stop charge button, which I assume it does for other reasons.I have a dumb question. (surprise, surprise)
In the charging section of the manual, it describes the process for ending a charge as:
I had always assumed that I could just unplug as I'm walking up to the drivers door, hop in, and bounce. I'm concerned if I have to take all of the steps above before I can get moving.
Anyone know if I'm reading too much into this?
Maybe it's meant to be a security measure, so you can't just run up and unplug a charger from someone's car, but I agree it sounds annoying. Seems like tying it to the lock/unlock state of the truck would be a better solution.God, I hope not. There should be a button you can press on the exterior to end the charge and release the plug. That would be a seriously annoying miss. If so, I'd at least hope the app has a stop charge button, which I assume it does for other reasons.
Yes, that's right. I should specify, in my car and I'm sure others, it has to sense the key within proximity for it to release the cable. I'd want it to work that way, even if I left the vehicle unlocked for whatever reason.Maybe it's meant to be a security measure, so you can't just run up and unplug a charger from someone's car, but I agree it sounds annoying. Seems like tying it to the lock/unlock state of the truck would be a better solution.
most EVs also unlock it whenever you unlock the doors. Some allow you set it to unlock automatically when it's done charging. I would have to believe at a minimum the former is implemented.I have a dumb question. (surprise, surprise)
With my Tesla I can just push the button on the charger and stop the charge but I have been told better to stop the chargeI have a dumb question. (surprise, surprise)
That's a nice addition. Hopefully they decide to publish an actual map somewhere that's updated so you know where to expect it to function.Now indicates that a highway assist icon will display when you are in an area where it is supported and are centered in the lane.
There is a new version of the R1T manual that has been posted labelled December 7, 2021 (Software Version 2021.49.x) - R1T Manual
Here is a list of new and changed items:
- New:
- Flashlight will flash 3 times to indicate it has a low battery.
- Now indicates that a highway assist icon will display when you are in an area where it is supported and are centered in the lane.
- Warning added indicating that the assist feature may disengage at any time without warning.
- New note indicating you can manually change the amperage draw amount to a lower value.
- Indication on page 95 that you can view what range estimates are based on and can reset the historical data.
- New grid on page 108 indicating what exterior storage is lockable and waterproof.
- Snow traction device section added to page 151 including indication that you shouldn’t use chains/cables on the 20” tires, but “textile-based” devices can be used.
I assume those Auto Sock things I've seen around lately.Any idea what a textile based traction device is?
