roth_nj
MA
Jeep Gladiator
mechanical engineer
any idea what the weight limitations are on the tail gate?
flabyboy
Minnesota
Mazda 6
Health Care
Source?
This is unlikely and would be a first for any manufacturer.
Edit: Saw this answered later with "CS". This is one of the times I think someone strayed from the script and got it wrong.
This was just confirmed with one of the new reviews. Mix of all the modes
SeaGeo
Brice
Xc60 T8
He said the epa estimate was made based on a mix good and bad moods ?. It was the review that had Beast on the front
Ben noted the same basically.
flabyboy
Minnesota
Mazda 6
Health Care
I think my favorite review so far was the one by what’s Inside? Family. Great footage
nfrank
Nathan
Bay Area, CA
F-150
I have a question about the GVWR. The manual states the GVWR is 8,532 lbs. Is this for both the Large and Max Pack? It's possible that the Max Pack will weigh up to 400lbs more than the Large Pack. That's a big hit to the payload capacity. Does anyone know if the GVWR is increased for the Max Pack version?​
Autolycus
ATL
ICE only :(
The max pack version doesn’t exist right now so there’s really no way for anybody to answer that.
RivianXpress
West Coast
R1T, Sprinter, TE300i, R1250GSA, KTM 500, 790
Retired Engineer
Can you or should you? Insulate away but unless you can be more specific about your drain plug idea I imagine your going to be doing a lot of unrepairable damage (and perhaps electrocuting yourself) along the way as I am pretty sure going down will lead you to the battery pack. Their is reportedly already a drain plug in the space where the spare tire resides.
I'm thinking under the seat cooler for ice and drinks ;-)
Amdolan
Anthony
Beverly Hills, MI
Dodge Durango
I would guess GVWR is the same since it is the combined maximum weight of the vehicle and any payload (people, gear, etc). It is usually limited by suspension capacity and thus battery configuration wouldn’t have an affect on GVWR. most likely, the max pack will likely have the same GVWR, but since it has a higher curb weight due to additional batteries, will likely have a lower payload.
crashmtb
Man oh Manitoba
crashmtb
Man oh Manitoba
protamine
Cincinnati
LG R1S, 992 GTS
CT Surgery
I feel like the biggest disappointment is that the seat adjustment is locked at speed. Why?
I think it's just a simple safety issue. I was adjusting my seat one day while driving and the switch stuck on, moving all the way back to where I could only reach the wheel with my fingertips. Of course when I tried to lean forward quickly the seatbelt locked. Grrr.
I find this interesting too. I dont move my seat in the city. I may adjust it a hair on a long highway trip just for a slight change/additional comfort. So either the rivian seats are so perfect or this is a strange choice.
This is an interesting item, wonder if I'd remember it in an emergency?
Rivian R1T R1S Rivian R1T OWNERS MANUAL Guide  is here! ? 1632920259895
CommodoreAmiga
INACTIVE
INACTIVE
I wonder if the manual is simply worded awkwardly. For example, it's common for vehicles to have "one touch" seat memory. Push the button once, and everything moves to a preset position. However, when I'm driving, I have to HOLD the button for however long it takes for everything to adjust. If I lift off of the button, then the movement stops.
I'm hoping that's all it is... Because it's not uncommon for me to need to make small tweaks to position if I'm on a road trip, or when driving home from a strenuous workout.
