Then you should understand comments like this, because you cited some of the variables that can affect wiper blades, but many/most poeple are unware of them. A cheap, worn out blade OR an expensive two month old blade may not remove all water precisely because of the reasons you cited, and more.I don't even understand comments like this. They're wipers - how good or bad can they be? Even the cheapest, worn-out rubber squeegee will remove all water as long as the entire edge makes contact and the rubber is still flexible and isn't oily or deteriorated by chemicals or sunlight.
A blade can become damaged or worn out in a few weeks depending on what happens to it. If you have daily snow and frost, and use your wiper blades to clear the windshield, they can be trash in a few weeks - the ice crystals are tiny knives that microshread the wiper. They can get contaminated by oil and antifreeze misted out by cars in front of you. And teh wipers may not be the problem - try doing a good cleaning of the windshield - it may be contaminated with a film that is causing the problem.
And of course, there are garbage brand new blades that don't even work out of the packaging. This whole market has evolved from a necessary replacement part to a "let's see what new marketing scheme we can come up with to sell even more expensive blades." I'm waiting for the "Empowered by AI" blades for $60 each.
