Real Rivian Photos & Videos
azbill
Bill
R1T, Mach E, Hummer EV SUT
In about 30 minutes. Correct they are taking i8
Too late, they are obviously headed to Irvine and were smart enough to avoid the heavy traffic in Phoenix by taking I10. That said I am only 8 miles from the EA chargers in Buckeye along I10.:confused:
electruck
Dallas, TX
2023 Rivian R1S
Is it me or at the end of this video the driver tried to check the acceleration?
No, most definitely a case of lead foot on display.
Ladiver
Jeff
Ca
I just drove from Goodyear to Orange County. I would have loved to "pace" a Rivian the entire way. I would have even stopped when/where they did even though my truck can go 600 miles. :)
kanundrum
Washington, DC
Giulia QV, R1S (S00N)
Holy RWD action LOL, the rear suspension was so compressed due to weight transfer/acceleration.
DuckTruck
Duck
PNW
Only eight days ago, we hit 1,000 posts on this thread, and now we're over 1,200. All we need are a couple of reliable pics of Launch Green (if it really exists), and I'll be good until the June Pickup² Event in Normal.
What if it's the same as Forest Green, without the metallic?....?
Way to go, Mister Tea! Nice thread!????
jimcgov3
Jimmy
No doubt! That definitely seemed like RWD only with the way it sat upon takeoff.
twinprice
Winston
Richmond, VA
Yukon XL Denali, Tesla Model Y, and LE RS1 - Hopefully!
With the active suspension, wouldn't we expect the Rivian to sit more level when accelerating like that? It is really sitting way back on the rear wheels! I do understand that it has 800+HP and I certainly don't know much about suspension or how a heavy SUV would really react to that kind of power.
kanundrum
Washington, DC
Car seemed to be in in the highest mode for sure but yes active suspension (air suspension) should have covered unless the person just floored it with a Comfy setting rather than a sport setting where it would adjust the rate of compression in this case.
CommodoreAmiga
INACTIVE
INACTIVE
Some "squat" under hard acceleration is a good thing -- it pushes the vehicle into the ground and improves traction. That's one of the reasons RWD is superior for off-the-line acceleration compared to FWD.
Also, this is a pre-production vehicle and we have no idea what test parameters are applied. Do we even know if "RWD" will be an option to select in production? Personally, I'd like it to be, so I can do a donut.
bajadahl
Alan
Austin, TX
Lexus LX470
Gosh I hope not.... I would expect the highest setting to have much more wheel well clearance for moderate offroading/overlanding.
I think CS has stated that it will be full-time AWD.
Rhidan
I've long wondered if RWD/FWD would be an option. CS told me several months ago that the Rivian will be full time AWD. During the Cold Weather Testing video, the UI had a setting that listed "Drivetrain" as "4x4." The website says this about the motors:
Powering the front axle is a compact 415 horsepower unit with 413 ft lbs. of torque. In the rear, a higher torque derivative delivers 420 horsepower and 495 ft lbs. of torque.
I suspect it may be way more complicated than RWD or AWD. I suspect the quad-motor system may be able to dynamically allocate power between the front and rear axles to maximize efficiency or torque. This is just my educated guess at this point.
We honestly don't even know what kind of motors Rivian is using. I know the dual-motor Tesla Model S has a PMSR motor in the front, but an AC induction motor in the rear. That allows the Model S to fire its induction motor when immediate torque is needed, but to shift power to the PMSR motor when you reach speed and longer range is needed. I suspect Rivian's quad-motor system might have the same sort of magic, and may be why the rear motors provide higher torque.
CommodoreAmiga
INACTIVE
INACTIVE
Much like how they've talked about a Tank Turn mode, I'm hoping for a Donut mode that will allow me to go RWD-only in certain circumstances. I see no reason or benefit to offering FWD.
Last I heard it was DC brushless. Not sure if that's changed?
By naming the company Tesla, they pretty much forced themselves to include an AC motor, imo.
Probably bigger motors compared to the front.
