Scojo1969
- Thread starter
- #1
R1T delivered last week. Was unable to ‘see’ any of my home WiFi mesh hotspots. Installed my wall charger this week, encountered the same issue.
Tried to no avail:
- restarting router, mesh points
- renaming the nearest hotspot to avoid special characters, spaces, etc
- turning off 5GHz band so that only 2.4GHz was available
- factory resetting nearest mesh hotspot
When I reset the hotspot it became visible to the R1T, but upon adding the hotspot to my network it disappeared.
Like most WIFi devices, the hotspot defaulted to a 192.168.1.x IP address and while it was it was visible to the R1T. As a security measure my home network is set to an alternative IP range. This has never been a problem for any of the client devices I’ve set up over the years.
Amazingly, $100k worth of Rivian gear seem to be incapable of connecting to a network that $3 IOT wall plugs do along with 47 other clients.
Anyone out there have a suggestion or workaround other than dumbing down my home network?
Tried to no avail:
