R1T home charging stops after about 9 hours.
mkronenberg1102
Michael
Spokane, Washington
xTerra, 350Z, Kia EV Soul
Real estate appraiser
Happened twice now.
Using Juice Box. It seems to stop charging at about the 9 hour mark. Started at 10% SOC. Unplugged and replugged to continue. Anybody else seen this?
Rivian R1T R1S R1T home charging stops after about 9 hours. IMG_4913
Mathme
Los Altos, CA
High Tech
I haven't...but check the Rivian or any limitations on charging and try power cycling the Wallbox (either unplug or turn off the breaker). Also check the Wallbox app and make sure the charger is on the latest software.
edman007
Ed
New York
CY R1S
Does the Juicebox report any errors? I have...er had a Juicebox, after one week of charging my R1S the magic blue smoke came out and the post Mortem showed the wire was melted off the lugs.
Juicebox has lousy reliability, mine was only 4 years old and the newer version apparently is lower reliability.
Also, Juicebox has options to stop charging after a predetermined amount delivered, so make sure the specs of the vehicle is set right and that plug in kWh/miles and kWh/miles to add are not set
