I have been losing anywhere from 4-7% per day and last night lost 3% in a 12 hour period. This is with PAAK turned off at home, climate powered off, bluetooth turned off on my phone. So I finally decided it wasn't any wireless connectivity issue and started exploring other possibilities. I'm sure everyone is aware of the reddit user who had the bad frunk latch so thinking of that, I popped the frunk lid and took a look. In my case the trim piece that sits directly above the grill and is sandwiched between the frunk lid and grill was clearly not attached correctly as there were gaps at both the right and left sides. It looked like it was rotated several degrees. I just decided WTH, I'll pull the trim piece off and see what happens. I did that at 11:46 Eastern time and in the almost 8 hours since then I have not lost a single mile of range or percentage of charge and I've been checking every hour so the truck has been awakened multiple times. Sorry I don't have pics to illustrate how out of alignment the panel was but my expectation was that I was wasting my time by removing it in the first place. As with all things, YMMV but looks like I may be on to something with my situation.Today marks the 7th day my R1T is has been sitting idle. The amount of wasted electricity is very disappointing to say the least. I will see what my local SC says when I drop it off this Friday. I completed an online repair ticket for this issue and to align some body panels.
-Vehicle lost 4.85 miles per day
-SOC started at 85% charge, now down to 73% (12% loss)
This is honestly really interesting info.Update: after 9 hours of losing no charge, I decided to put the trim back on just to make sure I wasn't losing my mind. I lost 4 miles of range and a percentage of charge within only an hour! So the trim is now back off and I will check again in the morning. Something very odd has occurred both times I've removed the trim. I am actually showing a gain of a percentage point each time I remove the trim piece. I brushed it off this morning as a one off but the same exact thing occurred this evening when I removed it. My working theory is that the trim piece is not allowing one of the components to think the hood is fully closed and turn off power completely. If that were the case I would expect one of the mechanisms to give up the ghost pretty quickly but I'm also not certain what components are powered to close the frunk, i.e. the latch may be completely mechanical and the struts are providing force with two separate sensing systems.
camp mode was helpful when I was camping. Have not tried it at home...usually just plug in my level 2 to top off, but worth a try.I consistently lose roughly 2-4% per day sitting outside in Seattle. Past few weeks have been between upper 30s and mid 50s. Not too pleased.
I will be thrilled if the root cause of my 4.85 miles a day of battery drain is that simple.
That’s awesome. Does your app say wake vehicle at the top?I lost a single mile of range overnight with the trim piece removed and I'm ready to declare victory. Now I just need to decide how to explain all this to rivian without them treating me like a crackpot.
Yes, I've been waking it to make sure I'm not getting stale mileage readings though. I think I stated in one of my posts last night that it is now definitely going into a deeper sleep mode than before as the wake function was timing out and would take 2-3 attempts to get it awake and to the cabin climate view. Previously I almost always was presented with the cabin climate view on opening the app.That’s awesome. Does your app say wake vehicle at the top?
Sounds like you have solved it. Do you have a pic of what trim piece you removed?Yes, I've been waking it to make sure I'm not getting stale mileage readings though. I think I stated in one of my posts last night that it is now definitely going into a deeper sleep mode than before as the wake function was timing out and would take 2-3 attempts to get it awake and to the cabin climate view. Previously I almost always was presented with the cabin climate view on opening the app.
5 clips and a tab on either side that slide under the side trim. The easiest way to remove is to unclip each side first then the middle clip and then the two remaining. The piece is thin and flexible so can pulled out easily.Sounds like you have solved it. Do you have a pic of what trim piece you removed?
Camp Mode is only helpful when you are opening and closing doors, it keeps things from cycling on. It does nothing different if the vehicle is left alone.camp mode was helpful when I was camping. Have not tried it at home...usually just plug in my level 2 to top off, but worth a try.
No idea what I am looking at here. Need a better explanation/guidance!5 clips and a tab on either side that slide under the side trim. The easiest way to remove is to unclip each side first then the middle clip and then the two remaining. The piece is thin and flexible so can pulled out easily.
