antennariidae
- Thread starter
- #1
So with the last update, I've seen a lot more discussion about this. I lokoedin the owner's manual and it mentions it very briefly, but doesn't really say anything. I am about to make my first relatively long-range winter trip with the truck. The destination is about 225 miles away and it is winter, so it is cold. So I am figuring out the best way to approach the trip given that the trip will be uphill (on the way out) and in the cold. So this seems to be a good time to ask about preconditioning as I need to plan for startup/charging, etc. I tried to go through the other threads and am confused about the dufference or similarity between warming up the cabin and battery preconditioning at startup. My understanding at the moment is that preconditioning:
1 - helps get the battery ready before driving so that the truck is ready for normal and efficient operation.
- this can be scheduled in the app through the climate interface after update 50.1
- possibly happens if you manually start the climate system some amount of time before leaving
Q: when you do the second method, is the battery preconditioned, or just the cabin warmed up? Is there a difference? Also, there does not appear to be an option to use the charger for power if you start the cabin process manually, so I'm assuming the only way to use the charger to power startup preconditioning is by scheduling a time and selecting use the charger for power? Is this true?
2 - gets the battery ready for more efficient fast charging
- my understanding is that this ony works if you are navigating through the Rivian nav system and have selected a charger for fast charging. The truck then heats or cools the battery as necessary when it thinks you are the right distance from the charger you have told it you want to use. And this only works if the charger you want to use is in the Rivian nav system.
Q: Is this an accurate description of what is happening? How much difference does it make? I really don't like how the Rivian nav app routes me. It is very time delayed with traffic conditions and almost always picks a worse route that Waze/Google maps. I have, on two occasions, had it route me the wrong way down one way streets due to daily road reversals as well so I am not a fan . . .
Thanks in advance for any additional information.
