Porsche Whistleblower: “60% of all delivered Taycan have battery issues that caused replacements, damages and fires”
RivianXpress
West Coast
R1T, Sprinter, TE300i, R1250GSA, KTM 500, 790
Retired Engineer
Well this is very concerning if true...
https://www.teslarati.com/porsche-whistleblower-taycan-battery-charger-fires-coverup/
By Alex Voigt
December 1, 2021
Rivian R1T R1S Porsche Whistleblower: “60% of all delivered Taycan have battery issues that caused replacements, damages and fires” taycan-flatbed-1-scaled
Posted on
“Six out of ten Porsche Taycan” ever delivered have a problem with battery management that affects and damages battery cells, requires replacement of cells and batteries, and is causing vehicle fires, according to a source working at Porsche’s headquarters in Zuffenhausen, Germany. Porsche is reportedly hiding the problem from customers and authorities and quietly replacing damaged battery cell modules without informing customers to cover up the problem. Tesla offered to help Porsche with battery management through Audi contacts years ago, but Porsche management at the time rejected any external help, saying it could handle everything internally, the source noted.
“The problem affects six of ten delivered vehicles,” the source, who could be described as a whistleblower, said.
A Risky Business
The Porsche whistleblower explained that the Taycan’s 800V high-voltage onboard charger used today does not control the charging process well enough and can overcharge some battery cells, causing them to overheat. For safety reasons, overheated battery cells are disabled and isolated from the battery pack, reducing battery capacity and thus the vehicle’s range. The problem occurs when the batteries are charged at a low AC speed of up to 7.5 KW, a common use case for all charging, such as at home or on low-speed chargers, the source said.
The 800V architecture of the Taycan, a vehicle the German automaker is proud of, has many advantages, but the strong current requires a very well-controlled charging process to avoid charging some cells faster than others. The battery cells in a BEV are always charged in parallel to shorten the charging time, but this carries the risk that some cells will be charged faster than others. If one of the many cells in a BEV is charged faster than the rest, overcharging and overheating can occur, which can lead to vehicle fires, if, for instance, an additional air leak happens.
About 1% of the 60% of vehicles affected, or about 360 Taycans out of 36,000 vehicles delivered, had a preventable vehicle, cable, or smoldering fire attributable to the problem, the whistleblower said. These are figures from Porsche’s internal statistics, which the company updates on an ongoing basis to keep track of safety issues. The reason the whistleblower, who works for Porsche in Zuffenhausen, is talking about the problem at all, risking his job and more, is that the company has decided lately not to replace the Taycan’s onboard charger, but to continue shipping vehicles and all future new Taycan models with the problematic system, which may pose a notable safety risk.
Rivian R1T R1S Porsche Whistleblower: “60% of all delivered Taycan have battery issues that caused replacements, damages and fires” porsche-taycan-charging-scaled
The Porsche Taycan’s charging port. (Credit: Porsche Newsroom/Twitter)
Porsche uses an inexpensive onboard charger that does not control the process well, the whistleblower explained to me in detail. Fires have occurred in the Taycan battery, the source explained, due to the problem described. Porsche is reportedly aware of the problem and is working on it, but the automaker has not solved it or informed customers or authorities so far.
Instead, the company is reportedly hiding the problem for cost and reputational reasons, the source stated. This is because if acknowledged, all Taycans would require a recall and the replacement of their onboard charger, and all batteries would have to be inspected and tested and, if affected, replaced. The cost, the source said, would be in the hundreds of millions of euros and the damage to the company’s image could be even greater.
A Remarkably Short Warranty
An apparent hint of Porsche’s challenges with the Taycan’s battery could be seen in the warranty for the all-electric sports car, which happens to be one of the lowest on the market with just 60,000 km or three years if following conditions (Porsche Warranty Requirements) are not met:
Vehicles standing longer than two weeks supposed to be connected to a charger
  • Customers must assure that the Taycan’s state of charge remains between 20% – 50%
  • Customers must make sure that their Taycan is not exposed to continuous sunlight
Vehicles standing longer than two weeks not connected to a charger
  • Customers must charge the Taycan’s battery before to 50%
  • Customers must check every three months and assure SoC remains at or above 20%
  • Customers must assure that their vehicle’s temperature is between 0C – 20C
While 160,000 km is an average battery warranty in the industry, Porsche confirmed to me the 100,000 km lower, 60,000 km warranty and its restrictions.
It is a well-known risk in the industry that when charging BEVs, an imbalance in the battery cells can lead to a sealed, encapsulated, and deactivated cell that can then overheat and cause battery damage and even fires if, for example, there is an additional leak in the battery box through which air can enter. Porsche’s 800V high-voltage architecture is more vulnerable in this regard than a low-voltage architecture such as Tesla’s 400V, or what other manufacturers use. Most of the BEV battery fire-related problems recorded in the past typically occurred in low-cost BEVs that lack sophisticated battery management systems or onboard chargers. Porsche has cut costs for its premium Taycan BEV, which poses a risk to customers, according to the whistleblower.
Rivian R1T R1S Porsche Whistleblower: “60% of all delivered Taycan have battery issues that caused replacements, damages and fires” porsche-battery
The Porsche Taycan’s battery pack. (Credit: @PorscheTime/Twitter)Costs and Savings
The cell damage can be repaired at great expense, but in most cases, Porsche chooses not to, the whistleblower said. To compensate for the vehicle’s reduced range due to encapsulated and deactivated battery cells, Porsche in many cases reportedly unlocks unused, reserved battery capacity, effectively tricking customers into thinking everything has been fixed, even though the affected cells are no longer in use and remain a potential risk, the source said. Customers who don’t know that a cell in their battery has a problem may not even recognize the reduced range in their Taycans because Porsche releases unused battery capacity and therefore the problem is not detected at all from them. This could explain why the number of the reported battery problems on the Taycan shared by the media is much lower than 60%.
For all vehicles Porsche informs needing a repair, the customer is charged 600 euros/cells module, although the internal labor cost is just 26 euros, the whistleblower said. Porsche charges customers even though no repair has taken place at all but just a battery module cell exchange, the source added. A Taycan has 33 battery modules with 12 cells each adding it up to a total of 396 total cells. Issues that happen and should be covered by warranty are, with regards to labor cost, paid by the customer, creating high service and maintenance profits for Porsche.
Considering the battery degradation that all BEVs experience sooner or later, the 60% Taycan customers who have the battery problem described by the whistleblower will have a lower total battery capacity than paid for after the so-called “repair” and will experience an earlier reduction in range and thus a reduction in vehicle value. If the problem of overcharging the onboard charging cell occurs more frequently, the damage can accumulate to the point where a complete battery replacement is required, according to the whistleblower. If what the source reported is correct over time, all 40% Taycans not yet affected by the issue may one day experience the same problem, depending on the charging behavior of their owners.
To pretend to have done a repair that never happened and accept a lower battery capacity caused by a cheap Porsche onboard charger without informing the customer would be misleading, to say the least. Worse, the replaced battery cells and modules are susceptible to the same problem, and owners accustomed to charging at home with AC power up to 7.5 KW may soon be faced with the same problem again after their battery packs have been “repaired.” Disregarding the cost and depreciation is bad, but the safety issue is the most serious problem of all and should be, based on the information my source shared, investigated by authorities in all countries where the Taycan is shipped.
Rivian R1T R1S Porsche Whistleblower: “60% of all delivered Taycan have battery issues that caused replacements, damages and fires” Porsche-Taycan-PH-3-scaled
A Porsche Taycan RWD displayed in a showroom. (Credit: Ma. Claribelle Deveza)An Invisible Fix
A different, more sophisticated charger for an extra 70 euros from the same supplier with a good reputation would solve the problem, but Porsche has so far decided against the hardware change, according to my sources. What sounds like a small additional cost is not small in the automotive industry, where target costs are a critical measure of team success and on which bonuses depend. The recent decision of Porsche not to use a better more sophisticated charger that would solve the problem for the foreseeable future made the source a whistleblower who rightly saw this as an unacceptable risk to customers.
The Taycan vehicles experiencing the charging problems are divided into three groups by Porsche and dealers, the whistleblower stated. Dealerships are under strict NDA and face losing their Porsche certification if they talk about the practice that the automaker is executing for years.
Affected Taycans are categorized as:
(a) Green – repair
b) Yellow – review with Porsche internal technical department
c) Red – replacement
All vehicles that fall into the “Red” category receive a new battery module or entire battery with spare parts that are available within 24 hours. Not all customers with “Red” designations are informed that the cell module had been replaced on their Taycan, the whistleblower said. The newly installed battery is reportedly “read out” and the data is displayed to the customers who are informed, claiming that it is data from the old battery after the “repair.” This, according to the source, effectively gives false proof that everything has been “fixed”. The new battery is then assigned to the old serial number, and this is how Porsche erases all traces that indicate fraud, the whistleblower said. That’s why it’s hard to prove that Porsche is cheating customers and misleading the public, the source explained to me. While vehicles designated as “Green” had been “fixed,” cars designated as “Yellow” are still undecided and need to be investigated.
If the authorities demand a Taycan recall and replacement of all onboard chargers and batteries, the associated costs will be in the hundreds of millions of euros the source stated. Provided that the whistleblower’s information is accurate, about 60,000 Taycans delivered so far would have to be recalled worldwide, with costly repairs, testing and hardware modifications. The reputational damage would be high and, like the VW Group cheating scandal, a major negative for the iconic automaker that claims safety comes first.
In the past, some Taycan battery fires, such as the one in a garage in the US state of Florida in early 2020 that occurred during nighttime charging, were never fully resolved after investigations began. My source said that Taycan fires were directly attributable to the problem with the charger and could have been prevented if Porsche had used a more expensive, higher-quality charger, as one would expect from a premium automaker. A small deviation during the charging process of only 0.1% can easily cause a vehicle fire when overcharged by 1%, my source said. The supplier has a reputable name, but a cheap charger was chosen to keep costs down.
Rivian R1T R1S Porsche Whistleblower: “60% of all delivered Taycan have battery issues that caused replacements, damages and fires” porsche-zuffenhausen-1
Porsche’s Zuffenhausen site. (Credit: Teslarati)
Teslarati reached out to Porsche to comment on the whistleblower’s claims and received following feedback on November 23:
“I checked with our R+D department in Weissach and all of the issues addressed lack any basis. Based on this information we can´t confirm any of the issues,” a spokesperson from Porsche said.
The source was confronted with the feedback from Porsche and stated in another phone call that only a very small team is involved in the matter, and it is no surprise for him that many within the automaker do not know about the described issues. Many more details were revealed, but they are not included in this article to protect the source. The source explained that in previous cases, Porsche made sure that employees who leaked information never got a job in the industry again.
Other sources informed me years ago that during the development of the Taycan, meeting target costs was a large challenge and that this may have led to the unwise decision to choose a cheap charger. Currently, the VW Group’s BEVs are lower-margin compared to the company’s ICE models and not all are positive, creating strong pressure from management to reduce costs. Given the Taycan’s high price and good sales figures, it is reasonable to assume that it is profitable, but it may not generate as high margins as the company’s iconic ICE models.
The whistleblower also said that years ago, Tesla offered to help Porsche with its battery management system, but the German automaker declined the offer. Around three years ago, Porsche asked Tesla through Audi contacts if they could help then, but at the time, Tesla declined. My source said it was pure arrogance on Porsche’s part that led to today’s problems, as Tesla had been willing to help them.
Previous problems with Taycan batteries led to a preliminary investigation by the US NHTSA in early 2021 into the sudden discharge of the 12V battery, which could result in the vehicle coming to a sudden stop. The NHTSA noted nine official complaints from Taycan owners, and Porsche recalled 43,000 Taycans to repair shops at that time. Taycan forum members report a variety of different battery problems as well as the media (e.g. a Taycan burned down in Florida), that may or may not be related to what my source reported. Overall, if we add all together, it appears that battery problems with the Taycan are not uncommon and with more age of batteries and vehicles, more issues may be reported. From what the whistleblower explained, the strategy from Porsche seems to be to solve or isolate technical issues without public notice.
The good news for the Audi e-tron GT that is produced on the same VW PPE BEV platform as the Taycan and shares many parts with it, is that Audi opted for a different and better onboard charger. The described problem is not existent with the e-tron GT, the source told me, but it’s unclear why Porsche isn’t learning from the Audi team in that respect.
Rivian R1T R1S Porsche Whistleblower: “60% of all delivered Taycan have battery issues that caused replacements, damages and fires” porsche-taycan-flatbed
A Porsche Taycan being towed. (Credit: Agero/Vimeo)A Note from the Author
As a writer, I do my best to thoroughly qualify every source, and I choose not to publish a story if there is any doubt about the credibility of the information or the source. I have direct contact with the person that provided the information in this article, know his identity and profession, had several calls and exchanges with him and know people who have met him in person.
My intent is not to disseminate misleading or sensational information, and this is a guiding principle for all my work. Since my source has passed my credibility check through multiple channels and has repeatedly provided many in-depth technical details on the issue, I feel it is my duty to inform the public with this article while I don’t have hard evidence and therefore can’t confirm the information to be right. According to the information provided by the whistleblower, Porsche has decided to take a big risk on the health of its customers for cost, profit and reputation reasons.
As a German who is proud of the heritage of the automotive industry in my home country, and as a former Porsche customer, I am truly shocked by what the whistleblower has told me. The cheating scandal has changed the culture in the German automotive industry many have told me for years, but it looks like the same structural problems remain and lead the industry right into the next big scandal.
Disclaimer
The Author, Alex Voigt does not own or had ever any Porsche or VW Group stock, derivates or other direct or indirect investments in the company. There has been never any business relationship between the author, Porsche, and the VW Group. The original and first clues to this exclusive and disturbing story came from Christoph Krachten, who came across it while researching his German best-selling book about Tesla.
Alex Voigt Patreon Page: https://www.patreon.com/AlexVoigt
Autolycus
ATL
ICE only :(
I guess that's one reason for a manufacturer to be very conservative with their charging rates early on!
sevengroove
R1S Launch Edition
This really is the kicker - that's got to hurt for Porsche.
Craigins
Chicago Suburbs
Software engineer
Rivian R1T R1S Porsche Whistleblower: “60% of all delivered Taycan have battery issues that caused replacements, damages and fires” 1638394798484
Nothing to see here, move along - Ford
Engi_Nerd
Western NY
Model Y LR, Alfa Romeo Giulia
Will be very unsettling if true, especially in combination with the recent widespread issues with the Bolt and Kona EV. Tesla may get a lot of crap about their build quality, but they seem to stand alone in having (painfully) ironed out the kinks and demonstrated they can build solid EV powertrains at scale. It's easy to look at the R1T, Rivian as a company, and all the good press and think it's a sure thing, but a single small defect sneaking in to these massive battery packs at this early stage could result in the company facing massive losses and going belly up down the line. Way more risk than buying a competing $80K vehicle.
moosehead
Presuming this is true, that is not only a massive hit to Porsche’s flagship vehicle, but it damages the overall brand significantly. It would also raise the bar on all EV battery technology.
Again if true, this is stunning that this would occur at all at Porsche, let alone on the heels of the VW diesel mileage debacle.
Signed, Captain Obvious.
SoCal Rob
Southern California
2023 Rivian R1S & 2021 VW ID.4
Information Technology
Again if true, this is stunning that this would occur at all at Porsche, let alone on the heels of the VW diesel mileage debacle..
Yeah, my first thought was to wonder if VAG learned anything from Dieselgate. If this is all true I’m not sure the corporation and corporate culture are worth saving. We have an ID.4 en route via ship as I read this and I’m more than a little concerned about buying a commuter car from VW now.
Denver_Paulie
Paul
'22 Porsche Taycan CT4s, '23 Rivian R1T
Serious journalism from a super credible site named Teslarati. That should tell you all need to know right there. An entire "article" based on one "whistleblower?" What happened to the days when a credible journalist had multiple sources???? While the Taycan has had teething challenges, I highly doubt that 60% of the vehicles sold had battery issues. Porsche/VW are not the most trustworthy corporate entities, but I doubt they would open themselves up to that kind of liability, again.
It will be interesting to see if the German automotive press pick up this story, then it would have legs and might actually have a kernel of truth. For right now, that article is basically fiction.
My first Taycan had some challenges, and was in the shop for 6 weeks. But, Porsche North America got the right parts fixed, and provided me with satisfactory compensation to cover my inconvenience. My second Taycan just passed 10,000 trouble free miles.
Khaneric
Simi Valley, CA
Never trust a German company to figure out electrical stuff. They are great mechanical engineers. That’s it.
THIS ALL DAY! I've loved all the VWs I've owned throughout my life but the issues that ALWAYS came up were electrical. It's one of the main reasons I won't look at any of the VAG electric vehicles.
aAlpine
Victoria, BC
2024 Quad R1S, Ioniq 5
So which is it? 800V DC fast charging? Or "low AC speed"?
SeaGeo
Brice
Xc60 T8
Except it's not even the high speed charging! It's on AC! Holy shit.
"The problem occurs when the batteries are charged at a low AC speed of up to 7.5 KW, a common use case for all charging, such as at home or on low-speed chargers, the source said. "
SeaGeo
Brice
Xc60 T8
To be fair, the ID.4 is 400v.
Sounds like it's an issue with their onboard charger converting AC to DC for the batteries.
lefkonj
Jeff
New Jersey
Gen2 R1S Tri, I4-m50
Very interesting but for a car that started shipping in 2019 with almost 30k in customers hands wouldn't this be all over social media? if the number is true that would be 18k cars with these problems. Wouldn't people be all over complaining about this?
Denver_Paulie
Paul
Exactly. The author is a hack, and his previous posting history shows him as a Tesla shrill. If there were 18,000 Taycan's out there that required significant service, or catching fire, there would be real press coverage. Not some a$$hat "reporting" it on f*cking Teslarati.com.
