J3400 is still in WIP status.SAE J3400 is an open standard.. not sure what you think the problem is.
and yet the proverbial writing is on the wall. It is far better than ccs1.J3400 is still in WIP status.
Same here. I was like..dude they didn’t even started properly and die already.Ok I read “R2” and “dies” and panicked for a moment ?
Plot twist - it has a turbocharged flat-4 sourced from Porsche instead.So, back to the subject, where is the charge port? ? YW
If it isn't on the right hand side then it will be in the left hand rear. I seem to remember reading somewhere that the R2 needs to have the charge port in the rear due to the RWD configuration. It's something to do with the charger using the inverter on the drive motor and with the rear drive version on R2 it doesn't make sense to charge in front. Commonality dictates all R2s will charge at the rear.So, back to the subject, where is the charge port? ? YW
Me too!Ok I read “R2” and “dies” and panicked for a moment ?
Is there a different picture with all components? Chassis cutout for charger wouldn't reveal the charge port type. It could confirm NCAS if it's small, but cannot confirm CCS.Probably not showing the charging side because it'll be obvious they aren't using NACS.
What's with the stabs that don't go into anything?
It's not just about what stations and vehicles are available today - its about what will be available in the next 10 years some of us would want to own an R2. Everything being produced in the future is moving to NACS.The vast majority of non-Tesla vehicles and stations have CCS1 ports. There's still a significant portion of Tesla stations that will be incompatible with CCS based NACS vehicles until Tesla rebuilds them. I personally still don't see the point, and I'm probably in the minority of people who have charged using a non-Tesla NACS station to charge a non-Tesla vehicle. The adapter worked fine.
Rear driver is my preferred spot - perfectly fits all the v3 superchargers as well as those of us who setup our home charger for both a Tesla and Rivian. I prefer backing in personally. Then when you open the door its not in the way to quickly jump out, plug in the vehicle, jump back in (especially bad weather).RJ said in a recent interview that the charging port will be in the rear because of the RWD configuration. They’re trying to cut costs and they don’t want to spend the money to run lines to the front of the vehicle.
