R1Tom
Some of the difference is good old smoke and mirrors.When you say there’s more drag, it demands more power: where do you suppose it comes from? The efficiency of the motors–the proportion of that the energy that goes in and mechanical force out to provide said power–absolutely matters.
It’s not whether motor efficiency matters more or less than drag if the discussion is about why your gen1 quad isn’t seeing the same range as a gen2 dual (with the same aerodynamics). Rivian literally lists officially different ranges for a reason.
(That said I’ve only seen them refer to it being “more efficient” and am not sure in what circumstances or in what ways)
The dual uses a strategy to disconnect the rear motor and eliminates that parasitic loss. The quad has to manually be disconnected, bit the key here....is it can be disconnected bit the rating and testing assume it is not disconnected.
So....disconnect strategy difference between the DM and QM accounts for a fair amount if difference.
