EV Sportline
evsportline.com
Upgrading Electric Vehicles
New product alert!
Team 1EV engineers worked a long time to develop the best storage solution for Rivian crossbars. The resulting design is very well thought out and thoroughly engineered to achieve several functional and performance objectives. First, the Team 1EV Crossbar Storage Mounts are designed to securely store factory Rivian Crossbars when not installed on the Rivian R1T / R1S. The Rivian R1T bed solution mandated that two sets of Crossbars mounts be storable and in a manner that nested all four bars on the front bed wall to minimize bed 'space' consumed with the storage. The design was carefully optimized to retain clearance for Team 1EV's RMaxx Soft Tonneau Cover and both factory Rivian tonneau covers (powered or manual). Next we wanted to retain clearance for Team 1EV's Tie Down Ring Hook & L-Track kit which installs on the front bed wall as shown in the photos. Rigidity and confidence in securing Crossbars when transversing off-road or during rough adventures required that our mounts attach to the Rivian using both upper and lower bolt bosses on the front bed well -- any mounting with less bolts would be totally inadequate. The next careful detail is the Patent-Pending 'dual-barrel' mounting link. Our goal was to emulate the factory Rivian latch pin to ensure a proper and full 'click-in' when attaching Crossbars to our mounts. You'll notice when storing four bars, we designed the mounts to stagger the bars slightly to enable fitting all four bars and retaining the most bed space. All these Patent Pending design features have been very carefully developed to create the best possible storage mounting solution for Rivian Crossbars. Our four Crossbar bed mount is also suitable for garage wall mounting. All mounting hardware is included for both R1T bed mounting and garage wall mounting.
Next, we wanted to create a smaller garage wall mounting system with similar thoughtfulness. Our two Crossbar wall system is designed to anchor into sheetrock walls and includes anchors and hardware. When space is tight or only a single pair of Crossbars are in play, our two Crossbar wall system is the perfect option.
Note: Rivian Crossbars not included
Specifications:
  • Patent Pending design by Team 1EV - Exclusively offered by EV Sportline
  • Made from extruded aluminum alloy
  • Anodized finish
  • Stainless steel truck mounting hardware
  • Sheetrock / Drywall / Stud / Plywood suitable mounting hardware included
  • Designed to work with Rivian R1T and R1S Crossbars / Cross Bars
VIEW HERE:
https://evsportline.com/products/ri...unts-for-truck-bed-or-garage-wall-by-team-1ev
Rivian R1T R1S New: Extruded Aluminum Crossbar 'Rack Mounts' for bed wall and / or garage wall! - EV Sportline / Team 1EV Rivian-Crossbar-Rack-Mount-4
Rivian R1T R1S New: Extruded Aluminum Crossbar 'Rack Mounts' for bed wall and / or garage wall! - EV Sportline / Team 1EV Rivian-Crossbar-Rack-Mount-3
Rivian R1T R1S New: Extruded Aluminum Crossbar 'Rack Mounts' for bed wall and / or garage wall! - EV Sportline / Team 1EV Rivian-Crossbar-Rack-Mount-7
Rivian R1T R1S New: Extruded Aluminum Crossbar 'Rack Mounts' for bed wall and / or garage wall! - EV Sportline / Team 1EV Rivian-Crossbar-Rack-Mount-9
Rivian R1T R1S New: Extruded Aluminum Crossbar 'Rack Mounts' for bed wall and / or garage wall! - EV Sportline / Team 1EV Rivian-Crossbar-Rack-Mount-11
Rivian R1T R1S New: Extruded Aluminum Crossbar 'Rack Mounts' for bed wall and / or garage wall! - EV Sportline / Team 1EV Rivian-Crossbar-Rack-Mount-13
Rivian R1T R1S New: Extruded Aluminum Crossbar 'Rack Mounts' for bed wall and / or garage wall! - EV Sportline / Team 1EV Rivian-Crossbar-Rack-Mount-15
andrew
Salt Lake City
Can you talk more about that? If I use the bottom two "rungs" for my crossbars then they have to be staggered? Do the crossbars not shift left and right at all while moving?
Do you have any data on the load that this can hold when using the upper and lower bolt bosses?
EV Sportline
EV Sportline
evsportline.com
The stagger allows us to fit all 4 bars on the front wall, and save room for bed mats / tonneau covers. The rack is slotted, you you can shift the rack up/down to clear bed mats.
See how these are staggered? The uppper / lower are right. The inner two are left. That is what I mean:
then if you just have ONE set installed, they can be installed in the middle or upper/lower and will not be staggered:
Rivian R1T R1S New: Extruded Aluminum Crossbar 'Rack Mounts' for bed wall and / or garage wall! - EV Sportline / Team 1EV Rivian-Crossbar-Rack-Mount-8
EV Sportline
EV Sportline
evsportline.com
Load rating is high; definitely strong - these are NOT 3d printed plastic. Will check with engineering and report back soon
Dog Wrangler
Can Max do pull ups from the mounts?
EV Sportline
EV Sportline
evsportline.com
Dog Wrangler
Sr5TRD99
Are these mounts load-bearing? I'm trying to figure out how to mount my factory crossbars on the top of my Xtrustion bed rack system so I don't need another set of crossbars, plus I like the quick disconnects with the factory setup.
andrew
Salt Lake City
Ok, I think I get it now. It's the "feet" of the crossbars that are the widest point so even though you can't see it, that's what is being staggered. And the gap between the middle two is the width needed for the "feet" to not interfere with each other's placement. If my understanding is correct, you could also stagger them by having one narrow and one wide instead of left and right, correct? Is there some kind of spacer to keep the bars from sliding left and right?
One other question, you mentioned sliding the mount up and down to accommodate bed mats and/or tonneau covers. Does that mean that you can only have either a mat or a cover, or will the mount fit between both?
EV Sportline
EV Sportline
evsportline.com
for sure, will have a spec posted shor
Yes, 300lb+ easily. We could go higher, but if you're mounting this on 'sheet rock', we want to be cautious of the anchor moreso than our rack.
EV Sportline
EV Sportline
evsportline.com
plenty of room for both 'bed mat' AND 'tonneau'. We designed it to work with both.
EV Sportline
EV Sportline
evsportline.com
