Mounting EZ Pass without damaging windshield tint film
Jac
Jacob
Connecticut
Rivian R1S, Volvo XC40, Honda VFR1200X
I am getting my windshield tinted next week to reduce heat penetration. What is the best way to mount/remove EZ Pass transponders from the windshield without causing damage to the tint film? My current plan is to order an EZ Pass mount from Amazon that uses suction cups to adhere to the windshield. Will the suction cups mess up the tint film? Are there better solutions to mount an EZ Pass on a tinted windshield?
AutoBoxClub EZ Pass Holder/Toll Pass Holder for Most US States/Toll Pass Windshield Mount/Easy to Install and Remove/with 4pcs Toll Pass Mounting Strips/UV-Protective https://a.co/d/2JMjjxY
connoisseurr
Connor
Northern VA
22 R1T, 23 MYP
I encrypt PDFs for Boomers
Do you have an EZPass that uses the plastic velcro for attachment to the windshield? If so, go buy a few strips from Lowe's or Home Depot (or your preferred big box store) and attach as you would on regular glass. I've been using windshield tint and the standard 3M plastic velcro strips for nearly a decade, with zero issues to the windshield tint.
Keep in mind, you're more likely to have the windshield replaced due to a crack and needing to replace the windshield tint, rather than damaging the film with adhesive velcro strips.
Jac
Jac
Jacob
Connecticut
Yes, my EZ Pass attaches with velcro strips. I was thinking about a solution that would allow me to avoid attaching the adhesive side directly to the new film. With those adhesive backed strips against untinted glass windshields all these years I knew I could remove the strips if I wished without causing an issue.
connoisseurr
Connor
Northern VA
22 R1T, 23 MYP
Just curious, why do you think you'd need to remove the adhesive strips? They will come off if you need them to. Use a hair dryer (not a heat gun) on max heat, roughly 8" away for 30 second increments. Adhesive will be plyable enough to remove. You can then remove any residual with most ammonia free window cleaner.
Additionally, you could try affixing your EZPass to your glass roof, or the backside of your rearview mirror. If you want to test the mirror application, get two rubber bands or zip ties, and attach the EZPass to the mirror. Go through a few tolls and ensure it works properly.
Oldsmobile_Mike
Manassas Park, VA
FG/FE R1T recv'd 3/31/2023
I build stuff
I don't know anything about front tint, but I do have an EZPass that attaches to the windshield with velcro strips. If I were getting tint on my windshield I'd probably have them cut it to go around the velcro (so the velcro stays adhered directly to the glass). You won't see it anyway, since the EZPass covers this whole area.
Good luck, let us know how it works out!
SparkMonkey
Florida
Has anyone considered or used the glass rooftop as the location for your EZ Pass? I know that's not what the toll company recommends, but I've seen people place them all over the windshield. I wonder if it would operate fine if attached to the glass roof.
RexRemus
Chuck
Chicago, IL
2023 R1S
Yes this was mentioned in a different thread as working just fine
Electrified Outdoors
Mount Airy, Maryland
EVoutdoors.org
Real Estate
Christopher
Christopher
South Florida
Tech
I've had suction cups for my toll pass and radar detector in all my vehicles with windshield tint and have never had any issues. I remove the suction cups regularly to clean the windshield.
Reactions: Jac
Timothykf
Tim
Toledo, oh
2019 Chevy Bolt; 2022 R1T Forrest/Black
Get the exterior, license plate mounted transponder. No obstruction on the windows and it’s further forward on vehicle. Have them on 3 cars without issue
scr4tchy
New York
Would need to have a license plate in the first place...
Sevn86
2025 BMW X5 M Sport
I have my windshield tinted and I’ve got my window sticker and toll tag mounted to a clear static cling sticker that I then mounted to my windshield. You can move them around whenever you want.
Acon
Albert
New York
Forrest Green Launch R1S
I have this exact setup. Works great and have even relocated without problems.
Timothykf
Tim
Toledo, oh
I don’t have a front license plate either, just screw into the bumper anyway
