- First Name
- Rob
- Joined
- Nov 13, 2020
- Threads
- 58
- Messages
- 1,415
- Reaction score
- 3,166
- Location
- Pittsburgh
- Vehicles
- Jeep & R1T
- Thread starter
- #1
Hello My Dudes!
Over the past few months I've seen a few different attempts at creating a magnetic charging mat for the Rivian. Nearly all of them are expensive (including the one I used to produce) and most use off-brand pads. None are available as STL files that you can remix and print yourself.
First and foremost - this item isn't for sale. Like everything I've made, it's publiclyavailable to download, print or remix yourself. You can get it at the following link: https://www.printables.com/model/367488-riviparts-magsafe-charging-mat
When putting this together, I started with a bunch of requirements:
The design is one flat panel that attaches via double sided tape (or similar) to the top of the rubber pad covering the Rivian POS wireless charger. I decided not to replace the rubber mat as doing so would certainly require unplugging the Rivian charging pad, which is a small pain. It's rounded where it needs to be including one the sides so it fits perfectly in the sloping groove.
It's designed to work well with iPhone Minis to iPhone Maxes (Maxis?) and also with most cases. The case on the iPhone 13 Pro pictured is a OtterBox Lumen - and there was still plenty of room.
The pads themselves are held in place well with friction. They are very tight in the opening. I've also designed a blank (included as a second STL) that can be printed and inserted the mat in lieu of a second MagSafe pad, as shown.
Printing is SUPER quick and easy. I was able to produce the version shown in under one hour using my Bambu X1 - including the blank!
Anyway - I hope you like it. I'm happy to hear feedback or suggestions on improvements. I'm happy to incorporate good change ideas into future versions, and the license attached to the file allow for remixing as long as it's non-commercial.
Speaking of commercial - as mentioned above, I am not planning on batch producing these at this time. (that's why this is being posted in the Mod Forum and not the vendor offers forum) You're welcome to try to change my mind , but that's the plan currently.
Please download and print it and let me know what you think!
- It had to work well for all sizes of iPhone without modifications to the vehicle.
- It had to use the OEM Apple MagSafe charging pads.
- It had to be quick and easy to print (or batch produce) and install.
- It had to be attractive and compliment the elegantly simple lines of the vehicle.
