Lopsided/sagging suspension!!!
jebinc
I noticed the rear passenger side of the truck is lower than the drivers side, by quite a bit - all heights. to lesser extent, the front passenger side is also lower. As a result, the truck "leans right," and pulls right as a result. CS had me do several "hard resets," but that didn't change anything. I'm concerned about the lean and resulting abnormal tire wear. I have an open service request, but my SC (Bellevue) is now booking appointments for May 2023! WTF?
Thoughts/Suggestions?
connoisseurr
Connor
Northern VA
22 R1T, 23 MYP
I encrypt PDFs for Boomers
Many of us experienced the front right sagging. First time I’m hearing about the rear right.
Get your service department to re-align. Also have them check linesets, air bag, and comfort valve manifold (device that regulates air pressure at each corner.
jebinc
jebinc
I would if they could see me before May! I couldn't find any threads on this. If they exist, please attach a link or two! Thanks!
Dog Wrangler
I’m assuming you made it clear to them the truck is not safe to daily drive in it’s current condition?
jebinc
jebinc
And took it a step further suggesting they are on the hook for tire wear! Waiting to hear back from headquarters...
Dog Wrangler
Damn. Bellevue always seems to be struggling. I don’t recall reading about another SC that is booked out that far. You guys do also have the highest concentration of Rivians up there in the PNW though, which doesn’t help. Still need to serve customers quicker than that.
connoisseurr
Connor
Northern VA
22 R1T, 23 MYP
Jason C
Jason
Redondo Beach, Ca
Rivian R1T Launch edition
I had the same issue. It took 3 repeat visits at the service center before they dived deep into the issue. Turned out to be a leak in the air distribution manifold. After they replaced it and recalibrated my vehicle I’ve been good.
electruck4x4
Electruck4x4.com
I ran into this issue with my truck about 6 months back and found that cycling the suspension between high and low resolved it. It eventually went away all together (presumably from a software update...?)
jebinc
jebinc
Thanks! I tried that and the hard reset, before posting. Nada, unfortunately.
PappaBolt
Don
Bainbridge Island, WA
R1S, Corvette, 911
Tech
Bellevue is hamstrung by having a tiny SC that wasn’t intended for consumer service. Given the number of deliveries in the PNW it should be a top priority to increase the SC capacity (I believe this is already planned).
Waiting 4 months for an appointment is unacceptable. It’s only getting worse in the short term. Exacerbated by the need for all these appointments.
cbrcanuck
Vancouver
They should immediately start redirecting all new deliveries up to Vancouver. We’ll call it load balancing.
Dog Wrangler
That sucks. Rivian should have known just from the number of orders up there they would require multiple SCs. No excuse for waiting this long. In the near term they should have as many mobile techs working as they can hire and only handle things at the SC that can’t be fixed in the field.
jebinc
jebinc
It is as it appears to be…
