I've done this a few times, there are a few ways.I've got a JuiceBox that I've had for years. Works well, will charge both with an adapter.
As I previous stated, I only installed, tested that it worked and haven't used it since. It is VERY small and light and comes with ample cable if you need to get to different charge port locations. The only complaint I have (and others have stated) is that the LED ring on the front of the unit is always on (changes colors depending on charge state) and is pretty bright. Wallbox states that they will have a FW update to allow this to be user controllable. The other feature in the app that is nice is that you can dynamically adjust how many amps you want to output from the app (even while the vehicle is charging). For me, this will be beneficial as I'll want to try to use excess solar generation to charge the vehicle (when I'm home to monitor) vs pushing and pulling via grid. I have about $0.03/kWh charge from SCE when I pull banked solar generation back from the grid, even though it is minimal, I'll be damned if I'll willingly give them an extra penny!!! GRRR. I thought that load balancing was automatic as they units can communicate with each other wirelessly, not sure, I could be wrong ... couldn't find any detailed info on the site. I have separate 50Amp breakers for my two chargers, so not an issue for me.Currently have a Tesla Gen 2 unit for my X, going to change out to 2 JuiceBox 48s so I can load share. I would rather get the Wallbox 48 TBH but you have to run a communication wire from one unit to the other unit so that they load share. (ugh now that I've typed that out I question myself why I'm so lazy to not run a simple cat5/2 wire cable... )
Anyway.... yeah I'm going to load share a 60amp circuit so either EV can take advantage of the fastest charge rate if the other is not using it. I'll also pick up a 2nd J1772 Charging Adapter from Tesla for $50 (Sure Amazon might have them cheaper but for a 100k car, $50 is just fine to know it's not some ghetto POS) so that I can always keep on in the car and the other on the wall connector that the X will use.
@Tim-in-CA - What's your hot take on the Wallbox units? Love the size!
I jumped on the Wallbox site and asked them about this as I had a hell of a time finding the information out and have only been able to find a single video on the setup. Once they get back to me I'll give an update, wireless would be nice.As I previous stated, I only installed, tested that it worked and haven't used it since. It is VERY small and light and comes with ample cable if you need to get to different charge port locations. The only complaint I have (and others have stated) is that the LED ring on the front of the unit is always on (changes colors depending on charge state) and is pretty bright. Wallbox states that they will have a FW update to allow this to be user controllable. The other feature in the app that is nice is that you can dynamically adjust how many amps you want to output from the app (even while the vehicle is charging). For me, this will be beneficial as I'll want to try to use excess solar generation to charge the vehicle (when I'm home to monitor) vs pushing and pulling via grid. I have about $0.03/kWh charge from SCE when I pull banked solar generation back from the grid, even though it is minimal, I'll be damned if I'll willingly give them an extra penny!!! GRRR. I thought that load balancing was automatic as they units can communicate with each other wirelessly, not sure, I could be wrong ... couldn't find any detailed info on the site. I have separate 50Amp breakers for my two chargers, so not an issue for me.
For Wallbox PowerSharing you need to run Cat 5/6 cables between the units. They will not talk to each other wirelessly and must be connected to one another for communication.I jumped on the Wallbox site and asked them about this as I had a hell of a time finding the information out and have only been able to find a single video on the setup. Once they get back to me I'll give an update, wireless would be nice.
As much as I'd like to run another 60amp I'm out of space so have to make the most of it, there's a chance I COULD upgrade my subpanel but then we're talking a LOT more money.
More searching, found a video showing setup .... Looks pretty easy and would work great for someone that is sharing a breaker.For Wallbox PowerSharing you need to run Cat 5/6 cables between the units. They will not talk to each other wirelessly and must be connected to one another for communication.
Type | Charge Amps | Circuit Amps | Plug Type | Miles / Charge Hr |
Riv Portable Chrgr | Reg 120v | ~3 | ||
Riv Portable Chrgr | 32A | 40A | NEMA 14-50 | ~15 |
Plug-in Charger* | 40A | 50A | NEMA 14-50 | ~20 |
Riv Wall Charger | 48A | 60A | Hard Wired | Up to 25 |
