fleming23
GA
24 R1S Quad , 25 R1S Tri on-order.
I stumbled onto this video, which I probably would not have watched...but it started playing and I wasn't initially paying attention until I started hearing things I had not heard or noticed previously. Mostly body shop and repair center focused, but interesting data points.
Examples I found in the video
  • Gen 2 12v battery is now below the passenger seat instead of the frunk.
  • Heater grid behind the front fascia to prevent the radar from getting frosted over in cold weather
  • Charge port door actuator mounting changed to fasica instead of bumper (minor and not really something I care much about - but interesting
Dog Wrangler
Doesn't a dead 12v often prevent access to the vehicle? At least in Gen 1 you can still attempt to "jump" it to unlock and get your stuff out.
R1Tom
Wisc
Riv R1T
That is odd....really odd....
fleming23
GA
There are still jump leads in the rear, as has always been the case. They stated they added a positive post under the hood as well, but battery changes will require removal of passenger seat. Watch around the 4:25 mark of the video I shared.
Dog Wrangler
Yeah, they explain it fairly well in the video. Sounds like it is just as "convenient" as it was before with the post in the frunk area.
CaseyH
2022 R1T, Polestar 2 LRDM, Model Y Long Range
Wow. So per that video they will also be using Gen 2 replacement parts on Gen 1 repairs going forward. This would seem to indicate some of the Gen 2 parts are able to be retrofitted to the Gen 1. They use the Front End Module (FEM) as an example but its not clear if the Gen 2 FEM includes the Gen 2 Lightbar or not.
Electrified Outdoors
Mount Airy, Maryland
www.ElectrifiedOutdoors.com
2023 Rivian R1T Quad, 2024 Rivian R1S Quad
Real Estate
No more sheet aluminum. Mostly conventional and high strength steel. The use of advance high strength steel to replace conventional in gen1 tells me that made some worthy changes.
Morphine
Bill
San Diego
2025 Gen 2 R1T Dual Standard, Audi Q4 e-tron
Biotech
Also looks like they cold retrofit a NACS connector quite easily in Gen 2 vehicles given that it's a separate piece from the whole harness.
R1TFTW
Steven
Wewahitchka, FL
It battery was lithium ion it wouldn’t be so bad. Wouldn’t really have to worry about it… that being said… it’s probably not
CaseyH
Found another video about Rivian Certified Collision Repair Network (). One thing I had not heard before is they mention Rivian is also working on establishing a third-party, certified service center network. That would be awesome if they could start getting certified third-party service centers to supplement the Rivian ones.
BrayBay
Paul
Launch Edition R1S - Forest Green/Forest Edge
I'm not expert service repair technician, but I am still not understanding the rationale for the 12V battery being under the passenger seat. The whole video is talking about making the repair process easier, but seems like that is a lot more difficult to physically remove a seat when the battery dies.
Maybe I'm old fashioned and just want to replace the battery myself by popping the hood, loosening some nuts, and swapping the battery in a few minutes. This new design seems like it forces you to go to a service center.
The video mostly talks about Gen2, but with all the cost efficiencies being developed I'm guessing these design choices will be consistent with R2/R3/R3X?
kenyee
Boston
ML320
It's expected to be replaced every 2-3 yrs and now you have to remove an entire seat to get to it? 🤦
R1Tom
Wisc
Riv R1T
This has to be the single biggest bad decision in this vehicle. Imagine the added cost of removing the seat and reinstalling.
Not to mention if the battery has a short.....then the jump process won't work....and then how is it accessed? Break a window?
This alone could be a deal breaker for me.
The 12v battery should be ridiculously easy to get to.....not ridiculously hard to get to considering the failures and how they completely disable the vehicle.
