That's correct, it's the inrush current of the motor and the inverter's inability to provide the inrush current. Depending on the motor, it can be 1.5x to 2x the operating current. It can damage the motor long term, and/or shorten the inverter life. One solution (at least on line power, I have not tried this on an inverter but it should work) is a Soft Start. This type of device used to be common in industrial motor applications, although the wide spread use of VFDs (Variable Frequency Drives) eliminates the need for a Soft Start.I would Take Tommy's review with a grain of salt. If the power tools are rated under 1500W they should work if not under excessive load. The retarded start to full rpm of the saw may have been a function of the motor inrush current and the way the onboard inverter sends power. One of our resident engineers may be able to weigh in.
Part of the issue here is that the Rivian is a lifestyle truck, not a work truck. I suspect Rivian intends the inverter to be used for resistive loads, not inductive loads. Inverters must be designed to handle the extra stress of an inductive (i.e. motor) load, espectially when operating at it's peak rating. It's not an F150 with 7500w of "headroom".
