How is your defroster (not defogger) working?
SteelersFan
Justin
Winona, MN
Glacier White R1T Launch
Hi all. Been mighty cold here in snowy MN, and noticed the defroster is really struggling to keep up with keeping windshields clear. Wondering how everyone else's is doing and if I need a service ticket or to just suck it up? First winter with the Rivian, my non-heat pump Model 3 fought this as well but not as bad.
Thanks in advance!
Some random points:
Outside temps were at or well below 0F.
I park (and charge) in a semi-heated garage (50F or better).
Not referring to clearing the exterior of the windshields, this is the moisture forming inside from human/canine respiration, etc.
I am selecting the red defroster (2 presses) not the blue defogger (1 press).
Air blowing on HI defrost is far from hot (normal?)
When on auto, truck does a nice job keeping cabin warm
Rear and mirror defrosters work great
Couldn't care less about range loss, to be expected with the cold and batteries.
Arky
Subaru WRX STI
Use the defogger - it will do a better job at fixing the problem you're trying to solve. In my experience it clears up very quickly.
Works fine but I don't have a canine currently.
SteelersFan
Justin
Winona, MN
Will try, thanks. Unsure about making the A/C run with those exterior ambient temps.
crashmtb
Man oh Manitoba
Greetings from Winnipeg! most cars I’ve had automatically run the AC in max defrost/defog mode. Perfectly fine to run the AC when it’s cold. Helps dehumidify the interior too. Additionally, keeps the compressor lubricated - better than it not running for 6 months.
Arky
Subaru WRX STI
You need the AC to remove moisture from the air. I would assume the defroster is much more focused on heat so it won't blow as dry cool air.
At least when I tried it I only had to have the defogger on for a minute or so before it all just disappeared then I went back to normal cabin heat/fan/etc. This was at ~15F. I haven't done real extensive testing with it because it just seemed to do what I wanted right off the bat.
thedole
Portlandia
R1T LE
Brewmeister
When I turn on defog and then cycle it off it fails to go back to my original setting of AUTO. I have to re enable AUTO climate every time I use defog which is a lot in the northwest.
SoCalTravels
Southern California
Hyundai Nexo, Lexus RX450h
Cabin gets uncomfortable after a short time.
Ours too. I wish there was an option to adjust fan speed. Gets uncomfortably hot.
