Refresh Cache and Cookies
⛔️ If you're currently having issues accessing the site, please clear your browser cache and cookies for Rivianforums.com. ⛔️
Hitch pins enabled in All-Purpose mode?
dmc94
Rivian R1T - GW/FE/20"
Hello,
I am in the market for a new hitch bike rack and have been looking at the Kuat Piston Pro X since it has brake lights built in, which I would love to have as Rivian's lights are fairly small and adding a rooftop tent covers another brake light as well.
The rack uses a 4-pin connector (I'd use an adapter) but I want to know if this will work while driving in all-purpose mode, or if the pins are only turned on in tow mode which would be a deal breaker.
Thanks!
AltaTruck
Al
Pittsburgh
Mazda RX8, R1T, Alta EXR (road) , Alta EXR (woods)
Retired Science teacher
I have been playing around with additional lights for my motorcycle hitch hauler. So far I have tapped into the system via a four pole adapter and it will run the lights. The down side is it will put you in tow mode and turn off several of the sensors. I asked CS about it last week and they said you could not do it, but did say it could be an OTA update at some point. I now have a Zero Contact Interface unit which will draw only 12v power from the battery which I will start to play with tomorrow. If it works it shouldn't be too hard. Just removing panels to get to the wiring.
dmc94
dmc94
Good info. Let me know what works for you. Hopefully a software update soon.
Hitch pins are powered in every mode. The truck will ask if you want to put it in tow mode. Saying no still ends up disabling the blind spot detection sensors. It probably also disables backup sensors but I considered my experiment failed and went the same route with the zero contact sensors and a secondary 4-pin. I only wired for left/right brake lights and not parking lights.
Christopher
Christopher
South Florida
Tech
Where do you wire the zero contact to?
The Zero Contact attaches to the existing brake/turn wires. It does not make a direct electrical connection. It uses a sensor to detect current flowing through vehicle wires. Therefore, the vehicle does not detect a trailer being connected.
dmc94
dmc94
Does this work for just brake lights or turn signals as well?
