- First Name
- GoFastCampers
- Joined
- Apr 1, 2024
- Threads
- 0
- Messages
- 97
- Reaction score
- 185
- Location
- Bozeman, Montana
- Vehicles
- Rivian R1T
- Occupation
- Manufacturer
So unlike traditional campers, the GFC sits on your bed rails rather than in your bed. As you can imagine, there is, to use the technical term, a metric buttload of force acting on anything back there (especially on a 7k lbs truck doing 0-60 in 3 secs). So, we use an aluminum space frame like that found on a race car to hold everything together. Joints in that frame are machined from billet aluminum, which captures those forces and distributes them in straight lines through bolted connections into aluminum tubes. That way everything is free of stress fractures and is repairable/replaceable. Each part in that frame is unique to the truck it's designed for...but I digress.One thing mentioned in the video I noticed was the need to make the bed release accessible inside.
Any reason why you added that functionality vs just using the existing in bed release button?
Three of those tubes run along the tops of the bed rails (sides, front), and that obscures the Rivian's unique buttons. If you're inside the camper, it's nice to be able to open the tailgate without opening a side panel and reaching through to the external buttons on the outside of that frame rail, so we added one inside too.
You can also lock/unlock the rear lift panel on the camper from the inside, so you're just getting seamless function.
