atebit
- Thread starter
- #1
BLUF: (IMHO) expensive, but it worked with no issues.
Took a bit of a longish drive this weekend. I probably didn’t need to charge, but we were stopping for a while to eat and walk around. There happened to be a Flo station near by so I signed up for an account.
You have to pre-fund the account with a credit card, the minimum being $10, which is what I did. Arriving at the station it was pretty straightforward… connect the ccs connector, select the station ID in the app & click go. The session initiated without a problem and the truck called for 80KW from this 100KW pedestal.
This location used a tiered charging structure; $0.99 flat fee, plus anywhere from $0.43 to $0.65/KW, depending on time of day. IMHO this is quite expensive, but since we were already here & this was the first time I had tried to L3 charge this vehicle it was worth a try.
At that point I left it charging, expecting that once it hit the $10 limit in my account that the session would end. However, I checked the app about 10 minutes later to find that I had already rung up nearly $14.00, so I walked back to the station, terminated the session & moved out of the parking space. My account now shows a nearly -$4.00 balance. But since the only way to satisfy that is to add another $10, it will likely sit in that state for a while, as I typically do not need to charge on the road.
At least the charging session completed without any problems.
