Flaw or feature? Changing gears without putting your foot on the brake?
Ngkgb
United States
Anyone notice you can change gears without putting your foot on the brake? Was this by design?
sub
Rivian R1S, Tesla Model 3
EV's don't use different gears for forward and reverse. From a gearing perspective, switching from forward to reverse is exactly the same as switching from acceleration to regenerative braking. Same gears, the motor just applies torque in the opposite direction.
A gas engine that always rotates in the same direction needs the transmission to swap out gears in order to reverse the output. When you swap the gears, you want both sets traveling the same speed, 0MPH in this case so it's helpful that the car requires you have your foot on the brake. But that just doesn't apply to EV's. There's no mechanical reason why you couldn't switch to reverse traveling 90 mph.
You don't have a gear selector. Just like you don't have a gas pedal.
Audi Sq5 prestige, Rivian R1T
I wondered if it was going to cause damage. Thanks for the explanation.
CrazyOne
Acura TL, CBR 600RR, R1S
Since there is no creep and it has brake hold, there is no need to press the brake. Part of one pedal driving, I guess.
It's usually a safety issue, when the vehicle can creep because of gear change in ICE vehicles.
jimmyb2
IN
Chevy Express AWD, Lexus RX450h, Rivian R1S
There may not be any “mechanical” reason, but I am guessing that it would not reverse motor rotation if you tried to shift at that speed. I am certain Rivian has that locked out above some relatively slow speed because trying to reverse motor rotation at high speed would generate immense stress on the motor thus damaging it or severely shortening it’s life.
You could always try reversing at different speeds to find out.
txtravwill
Travis
Marble Falls, TX
R1T, F150
IT Software Director
Its kinda nice, feature for sure. Nothing mechanical as in a transmission to clunk/damage like ICE trucks.
sub
Forward/Reverse buttons are repurposed for cruise control when you are driving, so there isn't actually a reverse button to press. And it would be really bad if it did let you change to reverse at high speed.
Not for mechanical reasons, but just because it would be unintentional most of the time and our pathetic human brains couldn't adjust to an unexpected pedal reversal quick enough. It would make the accelerator pedal act like a brake pedal. Flooring it would feel like slamming on the brakes and releasing the pedal would let the vehicle coast. If you did that on accident, you would probably end up in an accident.
jb0063
Jim
Philadelphia
I've actually begun to notice some slight rollback when coming to a stop on even a slight incline. Has anyone else experienced this?
R1Thor
Joe
Lancaster, PA
2023 R1T, Limestone + Ocean Coast & Black Ash
Mechanical Engineering Lead
Since the latest update, yes. It's hit or miss, though (doesn't always occur)
CrazyOne
Yes, likely a software update. One day, I will stop all updates 😐.
HaveBlue
Lifted Lexus GX470, APR Audi A7, BMW 325Ci
On another note, how fast does the Rivian go in reverse?
