Jason C
- First Name
- Jason
- Joined
- Oct 21, 2020
- Threads
- 16
- Messages
- 361
- Reaction score
- 331
- Location
- Redondo Beach, Ca
- Vehicles
- Rivian R1T Launch edition
- Thread starter
- #16
I didn’t have to remove the black plastic housing. Did you print it out of flexible material? I was able to fold it and slide it into place. I figured every vehicle will be slightly different or possibly off center so I designed the fingers on the outside for that reason. That way you can cut them shorter if it’s too tight on the OD. I also use a .4 nozzle when I print them. I believe the ID is 37mm. I don’t have the cad file in front of me ride now. I tested various size ID and 37mm seemed to work the best for me.Can the OP talk about the install? Mine seemed to take quite a bit of effort to install. I removed the OEM black plastic housing and was able to just get it too fit. What was the ID suppose to be?
