Blueassassin
Some people like all wheel driftingSure, it's doable on all seasons/all terrains. But why? for 2% of the cost of the truck you can use something that is unquestionably better and safer!
WHEEEE!Some people like all wheel drifting![]()
Very easy to switch to fun mode by turning off ESCSome people like all wheel drifting![]()
Did you just have a tire shop swap out your stock tires for the snows? What did it run you?Minnesota here. I put on snow tires for all last winter. You'll never regret it, plus they are cheaper than stock tires. No need to buy dedicated rims as it would take years to get that money back (especially since your tires probably wont last more than 3 seasons)
Yes. $80. Discount tire.Did you just have a tire shop swap out your stock tires for the snows? What did it run you?
Yeah, I'm not going to get dedicated rims. I'd just grab some snow tires and have them swap them out.Yes. $80. Discount tire.
I would guess rims at minimum would cost $1200 including mounting. Every 3 years you would have to switch out tires for wear regardless.
It would take at least 12 years to get your money back on dedicated rims for winter tires.
True, but you would also have the benefit of having a spare if needed with one of your snow tires if mounted on rims.It would take at least 12 years to get your money back on dedicated rims for winter tires.
The problem is I have 21s and there are no alternatives. It appears you have 20s and have all the alternatives.Minnesota here. I put on snow tires for all last winter. You'll never regret it, plus they are cheaper than stock tires. No need to buy dedicated rims as it would take years to get that money back (especially since your tires probably wont last more than 3 seasons)
When did you test DM in snow?For those on the Fence with motor options, the DM is much better on this stuff. It feels much more planted than my QM did on the same tires.
Same here but I live in Colorado (not in the mountains) so the snow isn't typically that bad and melts after a day or two.The problem is I have 21s and there are no alternatives. It appears you have 20s and have all the alternatives.
