EV base running board install instructions for 2025 Gen 2 R1S
sanjoseR1S
San Jose, CA
2025 R1S performance dual max
All videos I could find online were for gen 1 R1S. The mounting brackets are different for 2025 as is some of the hardware on the panels. It took me a few hours to figure out the first side so I decided to make an instructional video to help out anyone else trying to put these on. Pretty easy once you know where everything goes.
emlo
R1T Dual Max Performance, R1S Tri-Motor
Damn I installed literally yesterday after work. Followed their new pretty poorly designed instruction. Thanks for sharing! The new brackets are definitely stronger than previous Gen.
emlo
the new instructions only ask you install 2 brackets only 1 and 2. Tech support confirmed only 2 are needed.
Here’s the updated instructions- they are pretty bad but if you read it a couple of times and look at pictures closely you can get it it.
sanjoseR1S
San Jose, CA
Wow they must have just updated that. I installed my first side last week and the instructions I scanned out of the box showed all 3 brackets being used.
What did you end up doing with the plastic panels? Such a pain to work with.
emlo
Left them off.
R1S Gen 2 Tri Motor, Tesla Model S Plaid, Jeep Gladiator Mojave
EV Base sent me an email and told me the brackets coming in my box/order are not the correct brackets for my 2025 R1S. They are sending correct brackets in a separate order. I'm glad they told me this.
EVBASE
EVBASE
Rivian R1T/R1S
A big thank you to you for sharing this detailed installation video of the EVBASE running boards for 2025 Rivian 🚗🔧 Your guide makes it easier for everyone to install these running boards.
Thanks again !!
emlo
A big thank you to you for sharing this detailed installation video of the EVBASE running boards for 2025 Rivian 🚗🔧 Your guide makes it easier for everyone to install and enjoy the benefits of these running boards.
Thanks again !!
Did you watch the video?
DayTripping
Timothy
DFW
So do the Gen 1 trucks still need both brackets? I haven't put mine on yet so I'd like to know.
emlo
I used 3 brackets on each side my Gen 1 R1T and 2 brackets on each side of my Gen 2 R1S. The brackets are different between the 2 generations.
DayTripping
Timothy
DFW
Thanks, I wonder if they could retrofit. It looks like they mount on the step the same way as before. This looks like a better design and lower profile but I'd have to cut more away from the plastic covers.
emlo
Yeah you gotta ask the manufacturer. I would think they would not be retrofittable. But I could be wrong. They sent me the 2022-2024 version of the kit and then sent me the 2025 brackets separately.
EVBASE
EVBASE
Rivian R1T/R1S
yes ,it is different
EVBASE
EVBASE
Rivian R1T/R1S
How do you want to retrofit it
EVBASE
EVBASE
Rivian R1T/R1S
Hi friend
In this case, our customer service should have sent a email to you in advance :D
