blank_lemur
Todd
2023 R1S Gen1 Quad
Just curious, what is it made out of? The description just says "Premium, Matte Black Plastic".
twraps
twraps
Iliya
Concord
twraps.com
We 3D print the anchoring mechanism and ball mount (with very high quality) using carbon fiber infused ABS. The puck has an aluminum case (not 3D printed) and the OBD to USB-C is injection molded plastic.
Revin
Kevin
Northern Vermont
2022 Rivian R1T / 2015 BMW 335i
Would you consider making a version for the passenger side?
Seano
Sean
Nor Cal
2x R1S, Porsche Box, BMW Wagon, Jeep Wrangler
Ok, so I've always used a "grabber" style for the phones (non-charging)... having never used this style charger, is it really as simple as set your phone there and grab it when you leave? It really stays in place? I use a slim(ish) silicone case on mine (Otofly 1.2mm) - would it still work?
SwampNut
Carlos
Peoria AZ
2022 R1T Launch Edition
Geek
Cases *can* interfere with magnetic mounts. You can get cases that specifically enhance the magnetic hold. For iPhones that's called MagSafe. That's what I use and it stays just fine even at high speed off road.
twraps
twraps
Iliya
Concord
twraps.com
Apologies for the delay, had a busy week...
Yes, that one won't have a charging version though, due to the lack of OBD port there.
With proper MagSafe case, as @SwampNut mentioned, it holds really well... I've never had my phone fall off, and I live in the Bay Area, it's basically off-roading on half the streets 😂
Revin
Kevin
Northern Vermont
No worries! That’s good to hear. I’d love to have a matching one for the passenger
drkp
Just got this installed. Easy install. Now trying to decide if I should go through the hassle of trying to tuck the wire back down and behind the dashboard.
Would recommend.
obfuscurity
Jason
Westminster, MD
Rivian R1T, Tesla Model 3, Audi SQ5
Excited to receive the charger today but quickly discovered a manufacturing or design defect. After installing it, I noticed the charger was flopping on the ball instead of sitting firm. Determined that the female portion of the ball socket (attached to the rear of the charger plate) wasn't attached firmly, and easily popped off in spite of the adhesive and screw. Further discovered either the threads in the charger are stripped or the screw is too small. Unfortunately I only have spare screws down to M3 which are way too large here.
@twraps would appreciate your help in getting this resolved as I've already removed the cabling and mounts from my prior dash mount charger.
Rivian R1T R1S Dashboard phone charger/mount by TWRAPS (left of the steering wheel) 1737228187539-ym
Rivian R1T R1S Dashboard phone charger/mount by TWRAPS (left of the steering wheel) 1737228242002-py
twraps
twraps
Iliya
Concord
twraps.com
Oh shoot that’s a defective one for sure! Let me send a new puck. Please DM me with the order #.
ChicagoR1S
Chicago, IL
Volvo XC90
Iphone 16's should get 15W with Qi2 and 25W with OEM MagSafe.
1) Will your current version hit 15W with a 16?
2) As others have asked, will you offer an OEM MagSafe option to get to 25W?
For the 25W, I believe it needs a 30W charger. Does the OBD have an output of 30W?
twraps
twraps
Iliya
Concord
twraps.com
The OBD to USB-C adapter is 30W, the puck is limited to 15W though. In reality I am getting about 12.5W and that would still depend on charge level of the phone, towards the end of charging it drops, which is regulated by iOS.
We can't offer OEM options though because Apple doesn't tolerate resell of their pucks. If more people request it, I will look into an option to have just a puck holder (with ball mount) so you can install any puck you want.
ChicagoR1S
Chicago, IL
Volvo XC90
Got it. I would suspect there are others like me that would want to maximize the 25W option on a 16 if possible. From a pricing standpoint, I'd think you could get close to your current price, even omitting the charger and offering the ability to snap in a MagSafe puck.
